R50/53 Just test drove a 2003 R53 S, first gear lockout?
Old Jan 18, 2018 | 04:59 PM
SpuuDy's Avatar
SpuuDy
Hey guys, I just test drove a 03 R53-S that had a new clutch. As I was coming to a stop, I was in 2nd gear, I pushed the clutch in to shift back to first and it wouldn't go in. I was still coasting when I tried this. The car went into first after going to neutral and letting the clutch out then pushing the clutch back in.
Is this normal for the 6speed in these cars? If not what could it possibly be?
Old Jan 18, 2018 | 06:14 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Most cars with manual gearbox will be hard to downshift into first while in motion, and the Mini is no different. It depends on the speed of your coasting. Your last sentence is that you executed a double clutching which spin up the idle gear to ease the job the synchromesh needs to do.
Old Jan 18, 2018 | 06:36 PM
SpuuDy's Avatar
SpuuDy
I had an r56s with a 6speed as well, I was able to downshift to first while moving. I understand these cars might have different transmissions. I guess what I'm concerned about is if this is a symptom of a bad synchro in first.. it didn't grind at all but I also wasn't moving when I put it in first
Old Jan 18, 2018 | 06:48 PM
pnwR53S's Avatar
pnwR53S
It it is significantly more difficult to get into first at low speed than your R56 I will be suspicious the gearbox has been abused, or seen better days. You should also consider the possibility of dragging clutch too, but I would think that should make shifting into first difficult while stationary.
Old Jan 19, 2018 | 04:42 AM
Derek86's Avatar
Derek86
Sounds normal to me. Seems like bad etiquette to put a car into first if you are still rolling.
2nd gear doesn't give you enough engine braking or something?
Old Jan 19, 2018 | 06:11 AM
Minibeagle's Avatar
Minibeagle
Originally Posted by derek86
sounds normal to me. Seems like bad etiquette to put a car into first if you are still rolling.
+1
Old Jan 19, 2018 | 07:32 AM
gumbedamit's Avatar
gumbedamit
Originally Posted by minibeagle
+1
+2
Old Jan 19, 2018 | 07:51 AM
SpuuDy's Avatar
SpuuDy
No you are correct, how ever when coming to a stop sign ( i don't fully stop) I put it in first Gear to gain speed again.
Old Jan 19, 2018 | 08:15 AM
gumbedamit's Avatar
gumbedamit
The only time I will shift down to 1st gear is when I'm rolling under 3-4mph.
Old Jan 19, 2018 | 09:36 AM
gsfent's Avatar
gsfent
Next time, just give the throttle a blip and then shift into 1st. With todays gearboxes, that should be enough (no need to double clutch). Remember 1st gear is pretty low, so don't be afraid to give it a good blip.
Regards,
Jerry
Old Jan 19, 2018 | 09:51 AM
Derek86's Avatar
Derek86
Watch for the 5-0.
I usually just leave it in second, habit I guess.
When I learned to drive stick I was told that first gear synchos tend to be built weaker/less effective because you really only put the car in first at a stop. This would be why it is hard to put the car in first whilst you are rolling, they aren't built for that. You can bypass this by double clutching the shift, which is why we have synchros in the first place.
Has anyone here ever driven a non-synchro'd transmission? It's an interesting experience...
Old Jan 19, 2018 | 10:08 AM
pnwR53S's Avatar
pnwR53S
Watch for the 5-0.
If you've ever driven cars like MGB which has rather weak and failure prone synchromesh, especially those in 1st and 2nd you would soon gain proficiency in double-clutching.
With tiny city blocks littered with stop signs like Portland, I often will just start in second in these repeating stop and go situation. The fear monger will tell you it is very bad for the drivetrain. If you a good driver (that knows how drivetrain works) and not in a hurry I don't see any evil. If I feel compelled to downshift from 2nd to 1st, like negotiating a very steep road I will execute a double-clutching as it make going into first at a few MPH that much easier. The other situation is when approaching a red light about to turn green, and I time it perfectly that I want to be ahead of higher power car next to me, I will execute a double clutch from 2nd in 1st so I can have the best accelerate when the light turns green and I am just rolling towards it.
It is all about practicality and flexibility in respond to the specific situation.
Old Jan 19, 2018 | 10:12 AM
Derek86's Avatar
Derek86
Which is why I prefer manual transmissions in general. Every automatic I've ever driven was in the wrong gear at the wrong time. My fiance's Mazda 3 is particularly bad because it has so many gears to choose from.
Old Jan 19, 2018 | 10:33 AM
pnwR53S's Avatar
pnwR53S
Back to OP's original question. As through these exchanges there is still his first hand experience and not mine. How well he can describe the exact condition and difficulty in downshift from 2nd into 1st while "coasting" and what his notion of coasting means to me. Since he drives a R56 manual would assume his judgement that something is not normal with the R53 he test drove should not be dismissed as normal.
There are many things that can contribute to difficulty to downshift 2nd > 1st at reasonable low speed. It can be a worn synchromesh. It can be bent shift folk. It can be chewed up dog teeth. It can be worn splines and/or their mating keys. It can be draggy clutch. It can be deteriorated shift cable. Hence I am not about to say it is normal without driving it first hand.
Old Jan 19, 2018 | 10:40 AM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
+3, however if it's below 5mph or so, and he's still having trouble, it's likely the transmission is a little low on oil. Totally reasonable at 100k+
Old Jan 19, 2018 | 12:27 PM
SpuuDy's Avatar
SpuuDy
I'm going to possibly test drive it again tonight, I will try a few things such as Revving the engine then trying to put in first to see if the synchro is going out. I guess what I am really wondering is if the transmission is locking me out of 1st (which most manual cars have a lockout on first gear). With your own R53 do you have to double clutch to put it in first, say at a stop light?
Old Jan 19, 2018 | 01:07 PM
pnwR53S's Avatar
pnwR53S
No. R53 should behave very similar to your R56 which I think has a very similar Getrag 6 speed.
Old Jan 19, 2018 | 02:39 PM
sarom058's Avatar
sarom058
^^this. I think in general, when test driving a car, I wouldn't even worry about double clutching or anything fancy. Just drive the car normally. Depress the clutch fully between shifts. Keep your foot off the clutch, and hand off the shifter when in gear. Come to a complete stop before shifting into 1st. Give it some throttle between higher gear changes and check operation of engine, transmission, mounts, suspension, brakes, etc. Listen for clunks, vibrations, pings, and other weird noises.
Leave learning to double clutch (unless you're already perfect at it) for cars you already own. And for heaven's sake, don't buy the car if you have any mechanical concerns. It's best to buy the best example you can afford with a near-perfect maintainance history than it is to buy something with undisclosed issues.
For more things to look for when buying a used r53, check modmini's video on YouTube. We can only help with good driving habits and common issue identification. Your eyes, ears, hands, and feet are the best tools at your disposal.
Old Jan 19, 2018 | 04:35 PM
pnwR53S's Avatar
pnwR53S
Here is one good photo (from Wikipedia) of the basic functioning of a gearbox. You can see the synchromesh (made of bronze alloy), dog teeth, male and female spline collars, the spring loaded detent wedges (keep the selected gear in place from slipping out), and the shift forks. It might be hard to see how all these work in unison until you have a chance to play with them first hand. I did back in high school days to teach myself in successfully fixed a Ford and a Fiat gearbox.
If the dog teeth are chewed up, the symptom is likely that sometime you cannot shift into gear but upon retry you can. The dog teeth that I refer to are the sharp teeth that are in the axial direction.
here is a photo of chewed up dog teeth
I took the Mini out today, and I made a point to test the 2nd to 1st downshift for you. I can do it without double-clutching at around 10 MPH without problem. I did do so gently, and there is no grinding or much resistance. But my Mini has never been abused.
Old Jan 19, 2018 | 07:12 PM
iwashmycar's Avatar
iwashmycar
It sounds like they couldn't get the shifter to simply shift into first with the clutch pressed in? You should be able to shift the damn thing into first on the freeway with the clutch pressed in!! (just don't let off the clutch lol)
I used to do that almost every time I was coming to a stop sign in preparation to takeoff again. No way should you have to stop or come very close before being able to move the stick if your clutch pedal is down.
Old Jan 19, 2018 | 07:23 PM
pnwR53S's Avatar
pnwR53S
can it be done?
You should make a video to show us how it's done, from any gear of you choice into 1st at just 60 MPH, and of course don't release the clutch.
Old Jan 20, 2018 | 09:05 AM
SpuuDy's Avatar
SpuuDy
So when we first drove the car the connector on the battery terminal was broken therefore it was loose. The lights were flickering and it was doing that first gear thing. The guy replaced the terminal and we test drove it again, the car didn't do the first gear thing and all the problems went away.
We ended up buying the car. It's a R53-S Grey with white top. 82,000 miles hail damage and needs tires and windshield. One owner car. We paid 3500 for it. I think we got a good deal.
Old Jan 20, 2018 | 11:44 AM
gsfent's Avatar
gsfent
Congrats! I did a windshield on my hardtop. $300. No big deal.
Enjoy!!
Regards,
Jerry
catseye
Jan 13, 2010 06:34 PM
Pahon St. James
Jun 28, 2007 04:26 AM
hafid
17
Aug 2, 2004 06:07 PM
ElonCooper
12
Jun 15, 2004 11:39 PM
D.D.
Site Feedback
Feb 15, 2004 11:28 AM
