R56 Annoying beeping!!!
Old Jan 8, 2018 | 05:37 PM
China76's Avatar
China76
Annoying beeping!!!
I have an 08 R56 S. When I start and turn off ignition, the car beeps. Started as just 3 short beeps. But now they're 5 long, loud, beeps. I thought it was a service reminder, but I thought I reset all of those. The display does say "SERVICE" when I start the ignition. Any help please. This is driving me insane.
Old Jan 9, 2018 | 05:50 AM
Capt_bj's Avatar
Capt_bj
if it says service ... you need something serviced
some things won't go away just because you 'clear' the indicator
when you clear oil service you reset a counter so the warning goes away until the next interval
but let's say the warning is due to a brake pad sensor having been tripped. If you clear the warning but have not replaced the sensor the indicator will come right back (brake wear sensors are 'consumed' when tripped) .... ditto if the warning is for low brake fluid ... until you fill the fluid to the minimum level the warning will keep coming back ....
Old Jan 9, 2018 | 06:11 AM
China76's Avatar
China76
So I probably need to take it in. It doesn't tell me what needs service.
Old Jan 9, 2018 | 07:44 AM
DneprDave's Avatar
DneprDave
The only sounds my MINI makes is a three tone chime whenever a warning light comes on. I haven't ever heard beeps.
Old Jan 9, 2018 | 01:40 PM
Capt_bj's Avatar
Capt_bj
Have you gone thru all the service items in the service menu? IME when the SERVICE indicator comes up, one of these is 'telling' - there's at least 6 items that can be checked/reset via the on board computer and the turn signal stalk' button.
you should find everything described in the "Everything under control" section of the 'controls' chapter of the owner's manual.
If you are complete 'hands off' person wrt maintenance and service items for your car, yes this probably means you need to 'take it in' but that doesn't mean a dealer .... any service shop that will look at MINI should be able to handle anything that's wrong.
Old Jan 9, 2018 | 05:11 PM
AZdsrt's Avatar
AZdsrt
The Capt'n is dead on. I got the service icon, looked it up in the manual. Sure enough, you can scroll thru the menu and see what service is due. In my case, it was telling me the brake fluid needed to be changed. That service is time based (every two years I think). It also gives you the option to clear the warning.
Old Jan 9, 2018 | 05:59 PM
China76's Avatar
China76
I did go through those but I'll do it again. I'll also check the manual. Hopefully I missed something and I can fix it. I don't like to take any car to a mechanic.
xenor
Site Feedback
Aug 27, 2012 08:50 AM
UKDragon
Jan 16, 2007 09:46 AM
moonman9j9
Oct 25, 2004 04:47 AM
wendy
14
Feb 5, 2004 01:40 PM
keb
27
Dec 23, 2002 01:30 PM
