R50/53 Trailer Wiring?
Old Jan 7, 2018 | 12:15 PM
CSP's Avatar
CSP
Trailer Wiring?
Is there a harness that doesn't cost $90 for our car? I see references to not being able to draw power from the existing wiring, but that should only mean that we need to run a wire direct to the battery, right? Why are harnesses so bloody expensive? Is there some type of converter box or special relay that drives up the price? Can I not just use one of the $10 universal kits?
Someone please learn me.
Old Jan 7, 2018 | 12:21 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Is there some type of amp limit? If you can put a pre-made harness that just plugs in then would think it was logical that you could use a standard auto quicksplice that you do not have to cut any existing wires to use.
If it is a voltage issue would think you could use LEDs.
Old Jan 8, 2018 | 07:24 PM
CSP's Avatar
CSP
I'm not sure about any amp limits. I'm admittedly fairly clueless in regards to electricity but I understand broad theories. I wouldn't be opposed to LED, but this is for those rare times I need to rent a trailer. Having a set of LED's to get around the power issue would be more of a headache than just shelling out for the mini harness. I think I'll research e36 trailer harnesses. They're pretty ingenuitive and I'm sure have a similar setup. A couple wires and maybe a resistor shouldn't cost $90+shipping.
Old Jan 14, 2018 | 04:06 PM
Whine not Walnuts
The harness I used on my chevy did nothing other than plug into the bulb plug so I cannot see how just splicing into the lines will not work.
darkus
27
May 24, 2012 06:38 PM
Ken Cooper
Jan 25, 2010 02:02 PM
ken o
Electrical
Feb 21, 2009 10:35 AM
wheelspnr
Electrical
Feb 28, 2005 02:54 PM
paulmon
Electrical
Aug 3, 2004 06:20 PM
