Dang Battery
Old Dec 14, 2017 | 11:27 AM
808keith's Avatar
808keith
Dang Battery
Think my battery not holding a charge... 2012 CMS All4.. still on factory battery.. no battery light.. no crank. I can jump it and it runs but when I turn it off, it struggles to start if it even does start.. SGII shows 14V so my alternator is good.. Merry Christmas Mini.. you get a new battery soon.
Old Dec 14, 2017 | 12:31 PM
AnOldBiker's Avatar
AnOldBiker
4th Gear - An Official NAM Greeter
I'm new to the Mini's, but have the battery checked, sometimes it's only the connections or it could have a bad cell. And from what I've been reading, make sure you register your battery to the vehicle when relaced if it is needed. (I miss the old days, at this rate, you'll need to register each time you fill the gas tank sooner or later)
Old Dec 14, 2017 | 12:35 PM
Fly'n Brick's Avatar
Fly'n Brick
5 years on a battery is getting close to about all you can ask of one. The other thing that can cause loss of electrical power is a failing alternator or a slipping serpentine belt. Time for a 'turn your head and cough' session with your go to wrench sounds like.
Old Dec 14, 2017 | 12:42 PM
AnOldBiker's Avatar
AnOldBiker
Like I stated, I'm new to the Mini. But 5 years on a battery ? My Dodge truck got 10 years.
Old Dec 14, 2017 | 12:43 PM
808keith's Avatar
808keith
I'm not getting loss of electrical power.. it's just not holding it's charge... asking over 5 years from a factory battery is asking a lot.. over the past few weeks i've noticed the cranking kinda slow and struggling.. not the usual cranking.
It's only being driven once a week if that since i've gotten my 4runner.. lol.. poor mini..
Old Dec 14, 2017 | 12:47 PM
808keith's Avatar
808keith
I got the carly app to register it.
Old Dec 14, 2017 | 01:16 PM
Pure Red's Avatar
Pure Red
Or less. I replaced both our 2012 MINI Batteries last year before they left us stranded. Both were testing weak and not holding a full charge anymore. Only my wife's Countryman required the Dealer Registration since it had that system, my Clubman had the plain battery system, so I changed that one myself.
With both of our new 2017 MINI's needing Registration when their Batteries come due, it will be a pricey repair even if I change both car's batteries and only use my dealer for the reset of the system. [Unless by then I buy a software kit that lets me do that myself]......
Old Dec 16, 2017 | 11:41 AM
2017All4's Avatar
2017All4
Super Moderator
Parasitic loads on these cars take their toll over the years. We have 2 cars that get cranked once a week and I run battery maintenance chargers on both all the time. Batteries have lasted much much longer because the float charge prevents destructive depth of discharge.
You can get 7 ~ 8 years out of a factory battery if it isn't put through discharge/recharge cycles too many times. Also depends on severity of ambient temp fluctuations.
Advice: Get a new battery and keep a float charge going if the car is started infrequently.
Old Dec 16, 2017 | 11:58 AM
808keith's Avatar
808keith
yeah keeping a float charge is best especially as I drive it once a week, but unfortunately I’m in a townhouse and the mini is parked in front on the street. So I can’t run a cord to it. The parking stall we have assigned are open stalls.
I cant wait to leave Hawaii and having a big house instead of a townhouse for the same price lol.
Old Dec 16, 2017 | 12:07 PM
2017All4's Avatar
2017All4
Super Moderator
But, leaving Hawaii means leaving Hawaii. Everything's a trade-off.
BTW, if after 5 days the ambient measured voltage at the battery drops below 12 then your battery is failing or there's a heavy parasitic load like a light bulb that's staying on.
Consider yourself fortunate that you are being given warning signs. Modern batteries offen just chug along and then drop off a cliff and one day they're just dead.
Old Dec 17, 2017 | 10:08 AM
Benibiker's Avatar
Benibiker
When my 08 MCS's battery went out I just went to NAPA and they had a NAPA brand replacement complete with the vent tube. I didn't even had to register it and it lasted a long time.
Old Dec 29, 2017 | 05:22 AM
2012CM's Avatar
2012CM
Can someone enlighten me on the registration thing?
I have a 2012 CM All4-S (Canadian), and my battery is on its way out.
Are you saying I have to get the dealer to put in a new battery? I can't just get one myself
and put it in ?
Old Dec 29, 2017 | 05:34 AM
Pure Red's Avatar
Pure Red
and put it in ?
It depends on which Charging System your vehicle has. Non Intelligent Battery systems just require a new battery, reset your clock and radio stations and you’re set. The higher spec vehicles , or newest vehicles, will have a small electronic device mounted on the Battery Ground Cable that monitors your Battery and works with the Charging System to optimize the life of the Battery and provide a more sophisticated charging system response to electrical loads. THESE vehicles require a reset of the Intelligent Charging System if a new battery is installed. Just look at your battery under the plastic cover in the engine compartment to see which version you have. Jaguar and Land Rover have the same thing, we just call it BMS or Battery Monitoring System. Started for us with 2010 models.
Old Dec 29, 2017 | 07:11 AM
dpike's Avatar
dpike
i swapped the battery in my '12 s all4 with an agm battery from advanced auto yesterday. the stock battery in it (2nd one warranty replaced) was lead with 360cca, the new agm battery is 680. no ics on my mini took 15 minutes to replace
Old Dec 30, 2017 | 03:53 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move this to the Fixing Problems & Issues area. Trying to do a little cleaning up here in the Countryman subforum until somebody volunteers to help out.
DaveTinNY
Detailing 101
Jul 18, 2005 10:18 AM
Kyle
Jul 4, 2005 09:55 PM
UKSUV
43
Mar 31, 2005 09:32 PM
Tüls
Off-Topic :: Autos
14
Nov 17, 2004 07:32 AM
MSFITOY
Mar 24, 2004 04:34 AM
