R61 :: Paceman Talk R61 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
R61 Clutch up-grade
Old Nov 30, 2017 | 10:50 AM
Markbett's Avatar
Markbett
Clutch up-grade
Anyone know of any performance clutches out there?
Old Nov 30, 2017 | 03:20 PM
mikey_t's Avatar
mikey_t
There are a number of threads discussing this very subject. Here's 3 of them;
https://www.northamericanmotoring.co...ch-review.html
https://www.northamericanmotoring.co...placement.html
https://www.northamericanmotoring.co...d-gen-yet.html
Old Dec 7, 2017 | 12:18 PM
Markbett's Avatar
Markbett
Not that anyone really cares, but I just placed the order for the OS Giken STP clutch kit. Includes a new flywheel. We'll see how it goes, but should give me more than enough clamping power.
Old Dec 7, 2017 | 12:43 PM
cstrumol's Avatar
cstrumol
Just got my JMTC clutch finished up. I cannot stress how important it is to change your slave AND master cylinder. My stage 3 was slipping like crazy, thought it was just the kevlar breaking in, changed the master and now we are holding all the powers.
Old Dec 7, 2017 | 12:59 PM
Markbett's Avatar
Markbett
Thanks for the advice!!
Old Dec 7, 2017 | 01:12 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That doesn't make any sense. The slave and master only act on the clutch when it is depressed so it Should be released when pressed.
If it was slipping the only way a slave or master could cause that is if they were holding pressure on the fork. I've never had to replace the slave or master on an R56 yet and done like 100 or more clutches.
Old Dec 7, 2017 | 01:17 PM
cstrumol's Avatar
cstrumol
From what I was told from the clutch vendor (who i didn't purchase the master from) is that the master has a check valve that can fail/clog and when you release the pedal, pressure remains in the line to the slave and the clutch doesn't have full contact on the FW and PP. I put 700 miles on the clutch before swapping the master, slipped in all gears on MapA of my tune. Within 100 miles of swapping it I'm holding everything I can throw at in Map B, dramatic turn around
Old Dec 7, 2017 | 01:28 PM
Markbett's Avatar
Markbett
Well, either way, I'll make sure my mechanic checks it all out he's pretty familiar with these cars. Thanks for the heads up.
Old Dec 23, 2017 | 11:40 AM
Markbett's Avatar
Markbett
Clutch installed. Man what a difference!!. Grabs and holds. No more feathering it in, to make the thing go.
Old Dec 23, 2017 | 11:59 AM
ProjectMini's Avatar
ProjectMini
How many Mile on the original Clutch good sr> MarkBett?
Old Dec 23, 2017 | 12:28 PM
Markbett's Avatar
Markbett
About 45k. I bought it with 29K and I drive it fairly briskly Plus with the up-gades, I spun that clutch more than once. I looked at what they took out and there was a lot less than 1/8" left on it.
May 25, 2017 09:08 AM
May 25, 2017 09:05 AM
May 25, 2017 09:01 AM
zsqure
R60/R61 Stock Problems/Issues
May 3, 2017 09:17 AM
IQRaceworks
Dec 12, 2016 08:46 AM
