Clutches And Vacuum Pumps Best Price!
ECS Tuning
Clutch Master Clutch Kits | MINI R52/R53 S/JCW
Do you plan on bringing your MINI’s engine output to the next level? The wisest enthusiasts build their drivetrain to match powertrain advances. The best place to start is with the clutch.
Clutch Masters has been manufacturing performance and street clutches for 35+ years. With five stages accommodated for, you can be sure to find the exact clutch for your needs.
From daily driven to track cars they have you covered.
Fitment:
R52/R53 MINI Cooper S/JCW (2002-2008)
Click HERE For yourR52/R53 MINI Cooper S/JCW (2002-2008) Options
South Bend Clutch Options |MINI R53 R52
South Bend Clutch has been manufacturing performance and street clutches for 40+ years. With four stages accommodated for, you can be sure to find the exact clutch for your needs.
$50 ECS Gift Card and Free shipping, Clutch Winner!
Keep the power under control
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S/ JCW (2005-2008)
Click HERE For your R52/R53 MINI Cooper S/JCW (2002-2008) Options
Valeo R52 R53 MINI S/ JCW Single Mass Clutch Kit
This single mass flywheel conversion kit replaces the stock dual mass in your 6 speed with a more reliable single mass setup.
Dual mass flywheels allow fluid-feeling clutch engagements and offer a more luxurious feel than single mass flywheels. With these benefits come significant drawbacks. Why convert from a dual-mass flywheel to a single mass?
Dual-mass flywheels are expensive, with the cost of replacement and is often double or triple the cost of converting to a single-mass flywheel.
We also carry the replacement clutch if you have already converted to Valeo.
Grab another gear!
Fits:
MINI South Bend Clutches: R50/R52 MINI Cooper (NON-S)
Bringing your MINI's engine output to the next level? The wisest enthusiasts build their drivetrain to match powertrain advances - and the best place to start is with the clutch.
so clutch
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible (2005-2008)
Click HERE For your R50/R52 MINI Cooper (NON-S) (2002-2008) Options
OS Giken Drivetrain Components MINI Cooper S/ JCW 2007+
Bringing your MINI's engine output to the next level? The wisest enthusiasts build their drivetrain to match powertrain advances - and the best place to start is with the clutch then the added Limited slip differential.
OS Giken has been manufacturing performance and street clutches since 1973. With two stages accommodated for, you can be sure to find the exact clutch for your needs.
Daily driving to full on track options
Fits:
R56 MINI Cooper S/JCW (2007-2013)
R55 MINI Cooper Clubman S/JCW (2008-2015)
R57 MINI Cooper S/JCW (2009-2015)
R58 MINI Coupe' S/JCW (2012+)
R59 MINI Roadster S/JCW (2012+)
Click HERE For your R55-R59 MINI Cooper S/JCW (2007+) Options
N14 MINI Cooper S/JCW Vacuum Pump & Pressure Converter
If your MINI’s brakes are starting to feel softer, or if stopping isn't as precise and powerful as it used to be, the problem may very well be your vacuum pump.
This vacuum pump assists the power braking system in providing ample braking pressure and is located on the side of the engine head. The pressure converter sits behind it in the engine bay and assists the vacuum pump/turbo.
ECS now offers a Vacuum Pump and Pressure Converter from Pierburg for your Gen 2 N14-powered Cooper S/JCW, remedying this performance-robbing braking issue.
Pump Up Your Brakes
Fits:
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE For your R55-R59 MINI Cooper S/JCW (2007+ N14 engine ) Options
N12 Engine MINI Cooper Vacuum Pump
If your MINI’s brakes are starting too feel softer, or if stopping isn't as precise and powerful as it used to be, the problem may very well be your vacuum pump.
This vacuum pump assists the power braking system in providing ample braking pressure. Located on the driver side of the cylinder head.
ECS now offers a Vacuum Pump from Pierburg for your Gen 2 N12-powered Cooper, remedying this performance-robbing braking issue and repairs a rattling or failed unit.
Soft Brakes?
Fits: ( NON S )
R55 MINI Clubman (2008-2010)
R56 MINI Cooper (2007-2010)
R57 MINI Cooper Convertible (2009-2010)
Click HERE For your R55-R59 MINI Cooper NON S (2007-2010) Options
Fitment:
Fits:
Grab another gear!
Fits:
so clutch
Fits:
Fits:
Pump Up Your Brakes
Fits:
Soft Brakes?
Fits: ( NON S )
