F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 FYI -- coding rear fogs to act as brake lights
Old Oct 18, 2017 | 04:23 PM
GDGR's Avatar
GDGR
http://www.minif56.com/forum/825-min...ts-coding.html
Old Oct 19, 2017 | 02:54 PM
2017All4's Avatar
2017All4
Super Moderator
Glad someone figured it out. I've been whining about this for a year.
Old Nov 28, 2017 | 05:05 PM
autoxtech's Avatar
autoxtech
i was wondering how you are coding this info? what is involved ? anybody get it done yet?
Old Nov 28, 2017 | 05:32 PM
handn's Avatar
handn
Works like a charm. Took 5 minutes tops. (Needs E-SYS, the ODB-ENet cable and associated data file.)
Note: I have factory rear fogs which makes it very straightforward.
Old Nov 29, 2017 | 08:40 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
Normally, use of the rear fogs is because of low visibility situations. If the fogs are now coded to be used as rear brake lights, will they no longer work for their intended purpose?
Old Dec 5, 2017 | 12:21 PM
Thats what I was wondering?
Old Dec 8, 2017 | 08:27 AM
handn's Avatar
handn
Just checked. The rear fogs work exactly as before. If they are on, nothing happens to them when you brake- only the original brake lights will light.
Old Dec 17, 2017 | 10:50 AM
2017All4's Avatar
2017All4
Super Moderator
It's been done using Bimmercode as well!!
See post #6 on:
https://www.northamericanmotoring.co...rcode-app.html
I'm hoping, but not optimistic, that Carly will add this as well.
Old Jun 22, 2018 | 08:52 PM
JCByrdman's Avatar
JCByrdman
I went the other direction and coded my “running” lights to work as brake lights instead of the rear fogs.
Keep in mind it only works if you don’t have the headlights on. However, I’m still looking to see what deeper ECU values I can dig into (I’m pretty fluent in German and hexadecimal)
Attached Thumbnails FYI -- coding rear fogs to act as brake lights-eee0239c-d060-4aaa-ab47-b78c965eb364.jpeg
Old Jun 23, 2018 | 10:59 PM
zagman's Avatar
zagman
I like where this is goIng!
Old Jun 29, 2018 | 07:03 PM
GP193's Avatar
GP193
Looks good JC!
Keep us updated!
I hate my brake lights!
Old Feb 29, 2020 | 04:46 PM
Eric_Rowland's Avatar
Eric_Rowland
Ok, so I coded my fogs to act as brake lights, all is good.
I recently sourced a euro switch that also has the rear fog lights, but can't seem to figure out how to let the car know it's there.
From another post I see:
Activate Rear Fog Lights:
3068 NSL_Verbaut = Verbaut
Code first, then cycle ignition, then restart Bimmercode for the below options
to show up
Activate Rear Fog Lights feature for lighting switch:
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht
But when I go into expert, I only see 3067 (LceTmsCoding2) and 3070 (LciMaster) edit: that was in demo mode, doh!
Anyone know how to get this done?
Edit:
Found 3068 in (expert) BDC/LceMaster/NSL_VERBAUT
Found 3064 in (expert) BDC/LceLampMapping3/
And VOILA! Rear fogs!
After NSL_VERBAUT the rear fog indicator worked, but the lights did not until the 3064 nsl_l, nsl_r was activated on the second round.
Old Jul 29, 2023 | 06:07 PM
Johnnyfr03's Avatar
Johnnyfr03
Revert fog lights as break light
I Need help reverting my rear fog lights as break lights.
Thanks!
Old Jul 31, 2023 | 02:25 PM
Eric_Rowland
Specific questions? The instructions are listed above.
Old Jul 31, 2023 | 04:40 PM
Johnnyfr03's Avatar
Johnnyfr03
Got it done.
Had to restore previous settings.
Loccusst
May 17, 2020 12:32 PM
KeyPlayaJim
Aug 9, 2013 07:14 PM
z3bum
Electrical
Apr 23, 2012 12:32 PM
Mister_S
Mar 18, 2003 09:12 PM
