2nd Gen FAQs 2nd Gen Common Questions & Answers!
What engine do I have? N12, N14, N16, N18?
Old Sep 20, 2017 | 11:57 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
To figure this out, first you need to know what model year you have. Next you need to know if you have an "S" model with the turbocharged engine, or non-S or "justa" model. "S" and JCW models can be easily identified by the hood scoop and badging.
Cooper (non-turbocharged) 2007 - 2010: N12
Cooper (non-turbocharged) 2011 - 2013: N16
Cooper S (turbocharged) 2007 - 2010: N14
Cooper S (turbocharged) 2011 - 2013: N18
Cooper JCW (turbocharged) 2007 - 3/2013: N14 (turbo, compression ratio, and other components differ from the S model)
Cooper JCW (turbocharged) 3/2013 and up: N18 (turbo, compression ratio, and other components differ from the S model)
The years above are model years, not calendar years, and the dates may be different for different models - R57 vs. R56, etc.
The best way to be sure is to consult the VIN decoder here:
https://www.northamericanmotoring.co...vindecoder.php
or
http://myminivin.com/
Then check www.realoem.com with your VIN and build date to help you understand your exact model and parts, some items (for example the HPFP) were changed after a certain date.
If you still have your original hood and engine/emission sticker, the engine designation is there under the hood as well. Information and photo credit to renchjeep.
Last edited by squawSkiBum; Mar 14, 2018 at 08:57 PM. Reason: thread consolidation and cleanup
Old Sep 21, 2017 | 07:30 AM
squawSkiBum
Moderator
For more information, our vendors have some great articles:
https://www.pelicanparts.com/techart...nt_Systems.htm
https://new.minimania.com/MINI_Coope...son_N14_vs_N18
Old Jan 16, 2019 | 06:54 PM
mountainhorse's Avatar
mountainhorse
Exclamation Incomplete link correction
Link is incomplete above..
Here it is again following search.
www.northamericanmotoring.com/forums/vindecoder.php
Old Feb 12, 2019 | 02:55 PM
Easy way also to tell is the shape/design valve cover also
https://www.ecstuning.com/b-bremmen-...engine-covers/
Mikey_22
Feb 12, 2020 04:18 PM
Juve
Oct 16, 2019 07:47 AM
tgoodspe
Sep 3, 2015 11:16 AM
fastzombie
Feb 8, 2015 01:06 PM
Cpages2
Jun 4, 2014 02:32 PM
