Suspension Wheel Spacers: $50 vs. $170???
Old Sep 7, 2017 | 05:46 AM
ioannes79's Avatar
ioannes79
So I've decided to put wheel spacers on my '07 MCS; however, in searching for a couple sets to buy I've noticed the prices vary greatly. There's not a lot of discussion about quality. My question is is a $50 set of wheels spacers as good as a $170 set? I mean, what can the difference really be, besides alloy quality, finish, weight?
What are your thoughts/experiences?
Old Sep 7, 2017 | 06:20 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
In my opinion, the actual spacers shouldn't cost much - maybe $100 or so for a set of four, depending on thickness. Where the cost should be applied is the wheel bolts. Your really want quality wheel bolts, and I would only buy from a reputable vendor. (NOT ebay)
Old Sep 7, 2017 | 06:42 AM
Qik420's Avatar
Qik420
The pricing I'm sure has to do with thickness as well. You can get some run O the mill 5mm spacers for $50 but for a set of good quality 12mm spacers WITH bolts you'll pay $220-ish. I'm sure the $50 set and the $170 set definitely have a difference in quality. Keep in mind you shouldn't go cheap if you want a precision built quality product.
Old Sep 7, 2017 | 06:52 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
you guys are overpaying for spacers, the most I've paid for a pair is 24 $
Old Sep 7, 2017 | 08:35 AM
ioannes79's Avatar
ioannes79
I'm looking for 15mm spacers with bolts. I don't want to cheap out just to save money, but if the cheaper ones are as good, then why pay more?
Old Sep 7, 2017 | 08:39 AM
Qik420's Avatar
Qik420
The cheaper ones aren't good.
https://www.outmotoring.com/MINI-Coo...pacer-Kit.html
Old Sep 7, 2017 | 08:40 AM
MrBlah's Avatar
MrBlah
I use cheap ones on the track it's a simple hunk of machined aluminum it's a common size too
Old Sep 7, 2017 | 11:12 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We actually have our own wheel spacers because we wanted them to be quality but affordable. Some features we did what 2 sets of holes to reduce weight and make them easy to install. Also making sure they were exact hub centric to fit the hub perfect and not move around. And lastly cut a very fine groove on the face of them to reduce the contact area on the face of the rotor to keep it from corroding and sticking to the hub over time.
5mm
http://waymotorworks.com/wmw-5mm-wheel-spacers.html
15mm
http://waymotorworks.com/wmw-15mm-wheel-spacers.html
20mm
http://waymotorworks.com/wmw-20mm-wheel-spacers.html
