Suspension STD AND UTI's at the same time??
Old Aug 22, 2017 | 08:57 AM
RedAggie03's Avatar
RedAggie03
Can I run the CravenSpeed Strut Tower Defenders AND the Under Tower Indurators at the same time? Will the bolts for the top hats be long enough?
I hope so, because I already ordered them both.
Old Aug 22, 2017 | 09:47 AM
nkfry's Avatar
nkfry
I would just recommend a set of the Craven STDs, the UTIs raise the front of the car a bit, and aren't needed in conjunction with a quality STD.
Not going to hurt anything, but it'll be overkill for what you need.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Aug 22, 2017 | 11:50 AM
Aspen's Avatar
Aspen
I read that as Sexually Transmitted Disease and Urinary Tract Infection at the same time, Yikes!
Old Aug 22, 2017 | 12:27 PM
1200K's Avatar
1200K
Same here, thought I was in the wrong place all of a sudden...
Old Aug 22, 2017 | 12:29 PM
RedAggie03's Avatar
RedAggie03
I usually overkill things anyway. But it will work?
Old Aug 22, 2017 | 06:13 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Sounds like a shot of penicillin may be in order.....
Old Aug 22, 2017 | 06:32 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Just say I do it because I can.
Old Aug 22, 2017 | 07:54 PM
ptiller's Avatar
ptiller
WebMD aside, what about the bolts? That would be my question also.
Old Aug 23, 2017 | 08:29 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
The bolts will reach to allow the installation of both the top and bottom plates. The bottom Plates (UTIs) will raise the ride height by 1/8 and you will lose access to 1/8 of the stud thread. The top plates (STDs) will still get a good bite on the studs from there. Like nkfry said though, just the top plates will do the trick on their own.
Old Aug 23, 2017 | 12:11 PM
RedAggie03's Avatar
RedAggie03
Thanks for responding
I wish I had known all I needed were the top plates when I placed my order last week though
Would you allow me to return the UTI's? Why not discontinue the UTI's if the STD's do the trick, don't raise the car, and are much easier to install?
Old Aug 25, 2017 | 12:02 PM
memo79's Avatar
memo79
I have both......and they do work with the stock studs from the mounts. Not overkill, IMO. As bad as the strut towers can get, I see it as insurance against any future event that would likely mess up the towers. 1/8" in ride height is negligible. I got an alignment done right after I put them in.
Old Aug 25, 2017 | 07:56 PM
RedAggie03's Avatar
RedAggie03
Thanks, I have very similar feelings
Old Sep 5, 2017 | 08:07 AM
RedAggie03's Avatar
RedAggie03
Before
After
Both installed and torqued properly.
