STD AND UTI's at the same time??
Can I run the CravenSpeed Strut Tower Defenders AND the Under Tower Indurators at the same time? Will the bolts for the top hats be long enough?
I hope so, because I already ordered them both. :lol: |
I would just recommend a set of the Craven STDs, the UTIs raise the front of the car a bit, and aren't needed in conjunction with a quality STD.
Not going to hurt anything, but it'll be overkill for what you need. |
I read that as Sexually Transmitted Disease and Urinary Tract Infection at the same time, Yikes!
Originally Posted by Aspen
(Post 4324225)
Originally Posted by nkfry
(Post 4324203)
Sounds like a shot of penicillin may be in order.....
Just say I do it because I can.
WebMD aside, what about the bolts? That would be my question also.
The bolts will reach to allow the installation of both the top and bottom plates. The bottom Plates (UTIs) will raise the ride height by 1/8 and you will lose access to 1/8 of the stud thread. The top plates (STDs) will still get a good bite on the studs from there. Like nkfry said though, just the top plates will do the trick on their own.
Originally Posted by CravenSpeed
(Post 4324499)
I wish I had known all I needed were the top plates when I placed my order last week though :cry: Would you allow me to return the UTI's? Why not discontinue the UTI's if the STD's do the trick, don't raise the car, and are much easier to install? :sly: |
I have both......and they do work with the stock studs from the mounts. Not overkill, IMO. As bad as the strut towers can get, I see it as insurance against any future event that would likely mess up the towers. 1/8" in ride height is negligible. I got an alignment done right after I put them in.
Thanks, I have very similar feelings
https://cimg4.ibsrv.net/gimg/www.nor...4cee9cee37.jpgBefore
https://cimg5.ibsrv.net/gimg/www.nor...fce7f1af1f.jpgAfter https://cimg6.ibsrv.net/gimg/www.nor...c4d0c26888.jpgBoth installed and torqued properly. |
| All times are GMT -7. The time now is 10:20 AM. |
