Drivetrain Rmw 250 "dominator"
Old Aug 20, 2017 | 07:48 PM
50shadesofr53's Avatar
50shadesofr53
Rmw 250 "dominator"
Picked up this RMW dominator cam, got it installed over the weekend. Took it out to test drive it and break the cam in for a day before a tune. Take the valve cover off and look at how close the rollers are from the edge of the cam....and piece of the cam chipped off...very disappointed in something I paid 500$ for from WMW.
Those chips were not there when cam was installed
Number 1 cylinder wore through the spark plug tube, and rollers are almost at the very edge of the lobe..
Assembled with Lucas assembly lube and broken in at 2k for 20 mins then light duty driving for 2 hours...this doesn't make sense
Old Aug 21, 2017 | 01:58 PM
mooser's Avatar
mooser
Rmw cam
What's Way got to do with it. You should call Jan at rmw he one that imports newman cams.
Old Aug 21, 2017 | 08:07 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
The OP's photo on the worn thru spark plug tube piqued my interest. So too is where you can see the rough casting as well as how close the rollers running close to the edge on some cam lobes.
I found this old thread with some interesting discussion on the more subtle aspects of cams.
Old Aug 21, 2017 | 09:55 PM
50shadesofr53
I just feel that I should have paid 150$ for a paperweight instead of how much I did.
I'm not one to go back and forth with a company about this and that for weeks on end over emails to get the same result as most companies, ultimately stop answering my emails.
The way I see it, i wasted alot of money, now I have a cool paperweight. On to the next company and hope I dont get a p.o.s. again
Old Aug 21, 2017 | 10:09 PM
BlwnAway's Avatar
BlwnAway
The spark plug tube problem is a known issue with some Cams, and you should have been forewarned if this is one of them. (Which it obviously is)
As far as the other issues, Newman did have a bad batch or two a while ago, I thought they had all been gone through already.
I've been happy with my Thmpr Cam, (his, not the NS) it's the only one that's even come close to working with my problem ECU.
Old Sep 15, 2017 | 06:34 PM
PhoR53's Avatar
PhoR53
did you realize the "lobe" of rmw cam is "longer" than stock right? so its normal to hit the tubes. Same as others cams.....sometime you have to ding the tube. Did you get Jan tune your car? i have had no issues so far.
Old Sep 16, 2017 | 05:01 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I did not think the dominator needed spark plug tube dents
Old Sep 16, 2017 | 07:06 AM
N2MINI's Avatar
N2MINI
Unless things have changed RMW & WMW don't normally see eye to eye so how did you buy a RMW cam from WMW unless it was used... If WMW imported it themselves than RMW had nothing to do with it. Granted maybe you talked WMW into buying it from RMW which sounds unlikely from their past, unless you had WMW do the install? He might would do it then...
Old Sep 16, 2017 | 09:57 AM
BlwnAway's Avatar
BlwnAway
The OP has never addressed this, but I'm wondering if it was just a typo that never got edited?
Old Sep 16, 2017 | 10:16 AM
pnwR53S's Avatar
pnwR53S
WMW is selling CNC ported Revolution Mini Works head as of today.
https://www.waymotorworks.com/revolu...rted-head.html
It gave me pause to wonder RMW - which is Revolution Motor Works. Very interesting.
Old Sep 18, 2017 | 03:35 AM
N2MINI's Avatar
N2MINI
That is news.. Wonder how that came about...
Old Sep 18, 2017 | 05:06 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Perhaps a - can't beat em, join em?
Old Sep 18, 2017 | 06:05 AM
MrBlah's Avatar
MrBlah
wow 2k for a rmw head? that's quite a discount isn't it? sure makes it a lot more tempting
Old Sep 18, 2017 | 08:19 AM
pnwR53S's Avatar
pnwR53S
You guys need to read more carefully. Revolution Mini Works and Revolution Motor Works.
Old Sep 18, 2017 | 08:29 AM
MrBlah's Avatar
MrBlah
It said jesus head, that's rmw
the link is dead now?
Old Sep 18, 2017 | 09:17 AM
N2MINI's Avatar
N2MINI
They are one and the same..Revolution Mini Works and Revolution Motor Works.
Is it possible it was a used head he happened upon and listed it on his site?
Old Sep 21, 2017 | 08:58 AM
Thinker2112's Avatar
Thinker2112
I am not seeing the RMW head on the WMW page... am I missing something?
Old Sep 21, 2017 | 09:04 AM
pnwR53S's Avatar
pnwR53S
vanishing RMW head
Thanks on the web have a way of vanishing with a trace. You'd need a Zeitmaschine.
Old Sep 21, 2017 | 01:28 PM
BlwnAway's Avatar
BlwnAway
As mentioned above, it was probably a used head the Way went through and decided to resell, esp at that price.
Old Oct 16, 2017 | 11:42 AM
_aj_'s Avatar
_aj_
I installed this cam, as purchased directly from Jan, and it did require tube denting. Since I had heard of this issue (re. installing any high lift cams in an R53), I checked clearances during install. 2nd pic is 'dented'. Honestly don't recall if Jan even mentioned this, but I do agree it should be made clear. OTOH I suppose it could be said that if the installer doesn't hand rotate the cam and verify all clearances are good then shame on the installer.
Attached Thumbnails Rmw 250 "dominator"-imag2595-1-.jpg   Rmw 250 "dominator"-imag2603-1-.jpg
Old Nov 19, 2017 | 05:50 AM
Whine not Walnuts
With winter around the corner, if not already here in some places, its good to get this thread bumped so any of those thinking about cam work know about the plug tube.
Old Dec 10, 2020 | 06:42 PM
jjcsnlynn's Avatar
jjcsnlynn
We just installed a RMW Road Supercharged cam and had .004 clearance to the spark plug tubes. Did not dent them as 246 cam supposedly doesn’t need denting.
Just curious what the minimum clearance should be?
Old Dec 11, 2020 | 01:53 PM
BlwnAway's Avatar
BlwnAway
I don't know this for certain, but there really should be little or no expansion in that area, wasn't no movement at all.
I would guess .002 would be fine
Old Dec 12, 2020 | 03:50 PM
jk6672's Avatar
jk6672
Should have done a little more research. I have the RMW Dominator cam, and I follow MOD mini, so I knew I needed to take a ball pin hammer to the tubes for clearance. The cam is $360, not $500. Sorry this happened, but that’s why these boards and YouTube are your friend.
Old Dec 12, 2020 | 04:40 PM
MrBlah's Avatar
MrBlah
I have the RMW dominator cam in one of my cars and I did not have to ding the tubes
