Cleaning engine bay.
Old Aug 10, 2017 | 08:19 PM
Scooter24's Avatar
Scooter24
Just trying to see what everyone's opinion is on cleaning the engine bay with a power washer with low pressure? Mine is real dusty and dirty and I really want yo dial it in bit not sure if rinsing with water is a good idea?
Old Aug 11, 2017 | 04:32 AM
Cenla Mini's Avatar
Cenla Mini
I ran across this a few weeks ago...step by step and really well done.
Old Aug 11, 2017 | 04:33 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I use simple green, let it soak a bit, soft brush what I can and then garden hose off. I will use a power washer on the bottom but not on the top side. I have found that gunk type cleaners put a white cast on rubber hoses, the simple green does not.
Old Aug 11, 2017 | 04:35 AM
Whine not Walnuts
I will spray a little amorall on the black vinyl/rubber parts. I think there is also a spray type silicone as well.
Old Aug 11, 2017 | 06:56 AM
crazy4trains's Avatar
crazy4trains
Stay away from a pressure washer. Buy some all purpose cleaner/degreaser. I use LAs APC degreaser that I buy at the local dollar store. 1 buck for a 16 ounce bottle and it works great. Saturate everything liberally with the cleaner and allow to dwell for 10-15 minutes. Works better on a warm, not hot, engine. Spray off with a gentle shower or a mist setting. Heavily soiled areas may require some agitation with a brush. Cheap paint brushes work fine. Once dry spray with your favorite dressing or just leave it as is. Once you do this the first time you can repeat every 6 months to maintain.
Try not to over-saturate electrical connections. They can tolerate getting wet but shouldn't be hit with high pressure water.
Also, I have heard that simple green is not good for uncoated aluminum and will cause pitting. I'm no chemist and I didn't stay at a Holiday Inn Express last night so do your own research and come to your own conclusions.
Old Aug 11, 2017 | 07:24 AM
Whine not Walnuts
I have the SDS for simple green. The SDS is an OSHA requried document that provides the various parts of any material used in construction and or fabrication. There is a SDS for steel rebar, a bag of cement and lumber.
There are nine products listed on the SDS, water is one of the nine, in Simple Green. Two of the products; sodium citrate (5% of solution approximate) and citric acid ( 1% of solution approximate) are food additives and both are acidic in nature. The SDS further states that Simple Green is "not expected to cause" respiratory, skin or eye irritation.
Will Simple Green cause the aluminum in your car to oxidize? Most likely but remember that aluminum oxidizes in plain old air and water. There is an old saying, "dilution is the solution". Rinse the engine off after you have used the material.
I like a clean car but I am not the type that wears leather gloves so the oil in my skin gets on the steering wheel. I am also not going to be concerned with using Simple Green on my engine.
Suum cuique.
Old Aug 11, 2017 | 11:50 AM
Capt_bj's Avatar
Capt_bj
a word of warning ....
many times one buys Simple Green in concentrated form ... for most cleaning 1:10 dilution with water is a good starting point. 1:1 is a very strong solution. Undiluted Simple Green has been known to remove the color under the bonnet - which is 'base' not protected with clear .....
I've used low pressure steam on my engines for years. A handy tool in the garage ... cuts grease and oil with no chemicals ....
AutoRight SteamMachine Multi-Purpose Steam Cleaner
Amazon Amazon
Old Aug 11, 2017 | 01:47 PM
Whine not Walnuts
Off the course here a little but with either chrome or aluminum, Marvel Mystery oil does a great job cleaning any scale/oxidation.
Old Aug 12, 2017 | 05:02 PM
crazy4trains
https://www.amazon.com/AutoRight-C90.../dp/B01JYVLF0Y
Yes, concentrated Simple Green is very strong. I just put the caution out there because there are other products out there that will do a comparable job cleaning without the damage concerns in addition to being less expensive.
Old Dec 4, 2017 | 08:09 PM
Vmaxx!'s Avatar
Vmaxx!
Yeah...
I could use one about now. A certain moderator poured DIRT all over my engine compartment!
Old Dec 5, 2017 | 05:08 AM
Whine not Walnuts
Hmm, poured or dumped? Would think that "pour" would be associated with a liquid and/or semi liquid where "dump" could be something more solid. Was this "dirt" therefore more liquid or solid?
Old Dec 5, 2017 | 05:46 AM
Vmaxx!'s Avatar
Vmaxx!
OK, Professor!☺
Old Dec 29, 2017 | 11:41 AM
miniCPA's Avatar
miniCPA
Has anyone ever posted pictures of the various MINI engines showing all of the parts that need to be covered before detailing?
I would like to detail the engine but I have a huge fear water and chemicals getting where they should not go.
Old Dec 29, 2017 | 03:49 PM
Whine not Walnuts
Relative to water and the engine, do you think the engine compartment can get water in it on a rainy day? An engine compartment submersed under water is one thing, spraying some water on and around the engine is another.
Common sense comes into play here.
Old Dec 29, 2017 | 04:28 PM
Whine not Walnuts
Below is a link to a good thread on cleaning an engine. Notice they talk about "wetting" not soaking. Again, common sense.
https://www.northamericanmotoring.co...ine-bay-430865
Old Dec 30, 2017 | 05:09 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Rather than spraying the engine bay with a cleaner and/or water, get a container of smooth hand cleaner like Fast Orange (NO pumice) or GOOP. Put some on your palm, then soak it into a paper towel. Use the paper towel to clean dirt, grease and grime from your engine bay, repeat until clean. It takes time but does a great job without damaging or wetting critical components.
Old Jan 6, 2018 | 05:29 AM
mini4mo's Avatar
mini4mo
I just use a sponge and car wash soap.
The trick is to not let it get too bad like the picture above.
Old Feb 21, 2018 | 09:25 AM
spikeyslam's Avatar
spikeyslam
Can I get it done at the dealership? It's time for my 1st maintenance. I got a little mud here and there. Will they make a fuss about it?
