N16 into N12 car
Old Jul 24, 2017 | 06:45 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
N16 into N12 car
Just picked up a shell in need of a motor
N16's are significantly cheaper than n12's are they a straight bolt in?
for those curious, water pump failed, no warning lights they drove till smoke. The Smoke was from the valve cover melting into the head. The center two pistons melted on the intake side. No galling on cams so it never oil starved afaik, there is melted piston on the cylinder wall.
Old Jul 25, 2017 | 04:43 AM
MrBlah's Avatar
MrBlah
nobody done this? belts same, intake/exhaust same, head same, waterpump/thermostat is the same, I've not found a sensor that was not the same.
block/oilpump/oilfilter housing are different, that's all I've found so far, who said these n16's are more reliable ?!?!?
Old Jul 25, 2017 | 11:05 AM
MiniToBe's Avatar
MiniToBe
I only did an N12 transmission into N16 car and so far so good. Im also swapping N18 into N14 car and it is in progress. You just have to give it a try i guess. the plugs might be different in terms of wiring harness, just double check that. for example, my N14 plugs are more square shape while N18 are more round.
Old Jul 26, 2017 | 05:09 AM
MrBlah's Avatar
MrBlah
n12 and n16 show the same part numbers for the sensors, so plugs are the same
Old Jul 26, 2017 | 05:14 AM
MiniToBe's Avatar
MiniToBe
What about the oil pump. I know on the N18, they have a "smart" pump what has a plug.
I guess the N12 comes with regular pump where the N16 has a plug. right?
Old Jul 26, 2017 | 05:48 AM
MrBlah's Avatar
MrBlah
well **** I knew it was different I did not know there was a solenoid on it
Old Aug 2, 2017 | 06:10 AM
MiniToBe's Avatar
MiniToBe
any updates?
Old Aug 2, 2017 | 06:16 AM
MrBlah's Avatar
MrBlah
sold the car, I'm not paying that much for a n12
