Runs well on high rpm and stall on idle
Old Jul 15, 2017 | 08:38 PM
TimBaleia's Avatar
TimBaleia
Hello
After head rebuild have an issue with my 07 r56 S.
It runs well on high rpm.
So i don't think its a mechanical issue.
All four have 180psi compression.
Almost half of the engine is new.
its hard to start it.
It starts when you press gas pedal.
No codes when it runs.
When this issue started i had P300 - P304 and P1497
My guess that its dirty injectors.
Will crack it open tonight/tomorrow to clean it.
I remember injectors have like 5-6 small holes in the center to injector tip
and than 4 small holes on the perimeter of the tip.
That 4 holes was semi clogged/dirty.
Not sure but if that 4 holes is responsible for fuel delivery on idle
and center ones responsible for fuel delivery under load/high rpm.
Than i think i know what is the issue - clogged injectors.
Any ideas/thoughts???
Thank you guys.
You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
Old Jul 16, 2017 | 06:48 AM
MiniToBe's Avatar
MiniToBe
get a reading even if the check engine light is not on. there might be codes. it looks like a vacuum leak or misfire...turn the car and unplug each coil at a time and see which one makes no difference.
Old Jul 16, 2017 | 02:37 PM
oldbrokenwind's Avatar
oldbrokenwind
'07MCS injector tips have one pin-hole, centered. If removed, you need a special tool to compress the seal --- for re-installation. In the 6+ years I've been following Mini forums, I've yet to read about bad injectors.
Old Jul 16, 2017 | 11:06 PM
TimBaleia's Avatar
TimBaleia
I just bent valves again )
This is the mini without the luck from all minis i had (((
will rebuild the engine again and will try to take as many pictures as i can
thank you guys
Old Jul 17, 2017 | 06:11 AM
MiniToBe's Avatar
MiniToBe
how did you bend them?
did you torque everything to spec and replaced the cam bolts?
where you located by the way?
Old Jul 17, 2017 | 09:45 AM
oldbrokenwind
180psi compression on all 4 AND bent valves????
Old Jul 17, 2017 | 12:00 PM
TimBaleia's Avatar
TimBaleia
Everything is to spec.
I think 2 valves was slightly bent.
Old Jul 17, 2017 | 05:01 PM
TimBaleia's Avatar
TimBaleia
i had 180 on all 4. 16 hours lated tried to start it and engine turned for 2 times trying to start and something went wrong. And now I believe i have bent valves again.
Old Jul 18, 2017 | 10:15 AM
oldbrokenwind
"--- something went wrong"??? A description of this "something" would be helpful for us. Other than a timing issue or foreign material in the chamber, not much else will bend valves.
When I rebuilt my engine, I swore "Everything is to spec." However, during break-in, several things happened due to loose hardware. Nothing catastrophic, just loose stuff.
If your "something" wasn't catastrophic, maybe another compression check to ensure valve integrity?
Old Jul 18, 2017 | 01:58 PM
TimBaleia's Avatar
TimBaleia
Im afraid i will be able to tell you what was that something only after remove head.
May be 2 intake valves was slightly bent and this causedtiming chain to jump.
Engine is not spinning free. It catches on what i think bent valves.
I highly appreciate your input. Was reading your posts about your closed deck engine build. Awesome job! Will post pics and vids in this thread. Please help me out if you have time im desperate with this mini. This is one is giving me so many problems(((
Old Jul 18, 2017 | 03:40 PM
oldbrokenwind
May be 2 intake valves was slightly bent and this causedtiming chain to jump. Bent valves are usually caused by timing chain problems, not the other way around. Engine is not spinning free. It catches on what i think bent valves. If turning the engine by hand, be sure to rotate it only CW (viewed from the chain end), and have all the spark plugs removed. Tight compression might feel like an obstruction.
I highly appreciate your input. Was reading your posts about your closed deck engine build. Awesome job! Thanx. Will post pics and vids in this thread. Please help me out if you have time im desperate with this mini. This is one is giving me so many problems(((
The video in your first post --- was it taken before or after the rebuild? There's a definite "clank" in there someplace.
Old Jul 18, 2017 | 07:14 PM
TimBaleia's Avatar
TimBaleia
That video was taken after rebuild. I did put 2 miles on the engine. It was fine on idle and good in high rpm. And next day on the first start its just "bent valves" i guess.
Old Jul 21, 2017 | 05:45 AM
MiniToBe's Avatar
MiniToBe
Do a compression test and dont assume anything until you see data/tests.
Sometimes one is exited to get the car on the road and forgets to take his/her time to tighten everything and do a final check.
take a breath and go through the steps again.
right now you need a compression test. BUT before that, make sure the engine timing is correct and so take the cover and do visual inspection with your locking tools. THEN, when verified, move to compression test.
