knock sensor - codes P13B8 & 2D8E
Old Jul 8, 2017 | 08:57 AM
DenisMcG's Avatar
DenisMcG
I just had the half engine light and CEL come on following a short drive. The codes scanned as P13B8 (Knock sensor, electrical: Signal input 'B', short circuit to ground) and 2D8E. From what I can tell, it could be the knock sensor, the wiring, or the DME. Does anyone know of a test that I could do that would confirm the problem?
Old Feb 24, 2018 | 04:12 AM
DenisMcG's Avatar
DenisMcG
I had completely forgot about this post until I got a PM from smokeysevin asking about it.
I found that my entire air intake system was rattling significantly. My Countryman is a base model. I made sure everything was properly tightened. I don't know if this was what caused the problem, but the code has not returned since.
Old Oct 3, 2018 | 07:09 AM
DenisMcG's Avatar
DenisMcG
I am bringing this post back from the dead since my half engine light and CEL came back on today with the same codes. I thought back to each time the problem has come up and there is one common denominator. Each time was immediately following a very heavy rain. I suspect that water is getting into the harness somewhere and triggering the problem. I have moved the car to the garage and will take it back out when things dry up. More to follow.
Old Feb 6, 2022 | 05:38 AM
gsredmini's Avatar
gsredmini
I am having this same issue, common denominator is rain and moisture. What did you figure out on this and what did you do to solve it?
idickers
Jun 13, 2021 07:14 PM
MiniClubbie
Apr 7, 2020 07:54 PM
egills
Dec 8, 2017 12:19 PM
egills
Dec 7, 2017 06:14 PM
toiletduck
Jan 15, 2017 11:48 PM
