Issue after a puddle of water
Old Jul 7, 2017 | 12:57 PM
miniuy's Avatar
miniuy
Yesterday was a very rainy day and after passing through a puddle of water too fast in my R56 justa (35 mph) and a few blocks later, the car began to shut down when I released the accelerator (below 1K RPM).
I stopped the car and spent almost 1 hour looking for where water might have entered, but the engine was totally dry, up and down. There was no sign of being wet.
After more than 1 hour (turned off), the car began to function normally.
Obviously, the warm engine helped to dry something.
I don't like things to be solved by themselves without even suspecting where the problem could be.
Anyone know what the critical points to check in a MINI engine bay or chassis when this problem occurs? (go through large amounts of water).
Old Jul 7, 2017 | 01:27 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
One can hydro-lock an engine with just 1/2 cup of water...something to think about when approaching a flooded area. And even under normal operation, any water splashed up to side of engine/cover would probably just evaporate somewhat quickly due to engine surface temps.
Since there is basically not much of a splash shield on right side of engine, I'm inclined to thinking the water did something to the alternator and/or accessory crank belt could have been slipping....just a guess cause some folks "puddles" are deeper than others.
And if this was a one time situation, dont over think it.
Motor on !
Old Jul 7, 2017 | 01:50 PM
Capt_bj's Avatar
Capt_bj
once I parked in an area of some deep wet grass (at church)
when I left, about 5 minutes down the road the car went into limp mode. I got home and shut the car off and planned to head to the dealer the next day.
after a few hours, started the car and everything was normal and the problem never came back.
all I could figure was either by sitting in the wet dampened something, or starting up sucked in just enuf from below that it impacted a sensor.
so I agree ... if the problem stays gone don't sweat it.
(btw the horns are mounted really low and a deep puddle can drown those. I'd check em a few times and don't be surprised if they fail as they don't like baths. I've replaced a few sets ....)
Old Jul 7, 2017 | 01:51 PM
miniuy's Avatar
miniuy
Motor on !
Thank you for your comment.
I was with this situation on my mind all the day.
You are talking about the engine right side and I passed the "puddle" with the right wheels!
It can not be a coincidence.
I'm going to inspect the parts you mentioned just to try to find something.
Thank you again
Old Jul 7, 2017 | 01:54 PM
miniuy's Avatar
miniuy
Exactly the same behaviour and resolution as in my case.
Thank you very much for the comment and the suggestion.
Old Jul 7, 2017 | 01:55 PM
-=gRaY rAvEn=-
Moderator
Makes sense then. Probably belt got really wet, less grip on crank pulley and maybe even temp drowned the alternator...all those parts are less than 10 inches from the street surface.
GL!
Old Jul 10, 2017 | 05:11 AM
65frank's Avatar
65frank
On the way into work this morning (heavy rain in Northern Illinois) I didn't see the water on the road until it was too late. Apparently the car that had it's 4-ways on didn't clue me in but in my defense I didn't have any coffee yet. Luckily I didn't have any problems but I will tell you it made me nervous for a little while.
Old Jul 11, 2017 | 08:54 AM
miniuy's Avatar
miniuy
I'm glad to read that it did not have any problems with your car nor generate any accident/damage!
Those water on the road are very treacherous
Old Jul 11, 2017 | 08:59 AM
65frank's Avatar
65frank
I usually avoid water (even when I had my Explorer) and find a different way but like I said, it was early, dark (no street lights there) & raining so I didn't see it until I was in the middle of it.
