Walnut blasting time!
Old Apr 23, 2017 | 11:17 AM
timski's Avatar
timski
I have a 2009 MCS with 212,000 on the body and about 160,000 on the engine.
Pulled the engine because I have a long list of things to do. Numerous oil leaks.....thermostat....timing chain, etc.
Take a look at the carbon!!!
One of the worst I have seen.
Now I have to figure out how I'm going to know when the intake valves are truly closed.
Have all the tools for walnut blasting.
I'm sure I will have a difficult time getting it all removed.
When removing the intake manifold I didn't expect to see the inside of the chamber so wet with oil. Installing a OCC as well. Is this normal?
Attached Thumbnails Walnut blasting time!-photo709.jpg   Walnut blasting time!-photo536.jpg   Walnut blasting time!-photo617.jpg   Walnut blasting time!-photo456.jpg   Walnut blasting time!-photo500.jpg
Old Apr 29, 2017 | 06:17 AM
timski's Avatar
timski
Sorry if the questions sound like they are coming from a nube....which I am not. Ha.
I didn't expect the entire intake chamber to be so wet with oil.
The plan is turn the engine over by hand and watch the valves come up and seal. I just wish I knew by looking at the cam if the valves are closed for sure. Why don't they just simply place timing marks on the components like Honda does? So much easier. There is a ton of carbon on the intake valves so looking at them doesn't really help. I guess I will watch them go up and if it looks correct spray a little carb cleaner and make sure it pools up in the chamber.
Old Apr 29, 2017 | 07:18 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Digital inspection camera helps !
Harbor Freight
middle of the page....
Old Apr 29, 2017 | 09:00 AM
timski's Avatar
timski
Thanks. I have one that plugs into my iphone.
I will give it a shot.
Old Apr 29, 2017 | 03:48 PM
Redhotz's Avatar
Redhotz
I sprayed carb cleaner in mine and let it set for 5-10 minutes. The two center valve will be closed at the same time and vice versa.
Old Apr 30, 2017 | 12:35 PM
seandallen's Avatar
seandallen
Suggestions?
I have a couple of things you might try. With the spark plugs out, you might see if blowing LP air in the cylinder leaks out the valves. Also, you could let some cleaner pool on top of the valves for 15-20 minutes and see if it leaks out down to the cylinder head (Which you could vacuum out or let evaporate).
That's my two cents'. You may have already thought of these.
Old May 9, 2017 | 01:35 PM
timski's Avatar
timski
After pics.
2 center cylinders are closed together.
Sprayed carb cleaner....it pooled up and verified they were closed. Blasted with walnut shells and bye bye carbon.
Attached Thumbnails Walnut blasting time!-photo124.jpg   Walnut blasting time!-photo889.jpg   Walnut blasting time!-photo628.jpg   Walnut blasting time!-photo921.jpg
Old May 13, 2017 | 07:02 PM
Torquenut's Avatar
Torquenut
Can you show your walnut blaster? I going to take my engine out also, change out clutch, timing chain, waterpump and check the valves. If I need to walnut clean was thinking of using a harbor freight blaster, not sure if that will work.
Old May 13, 2017 | 07:22 PM
timski's Avatar
timski
Sorry not the best pic but it's the 20 lb media blaster from HF. Seen in the bottom of the pic.
My air compressor is a Quincy 20 gallon seen in the other pic.
I'm using the BWM/MINI OEM wand and manifold adapter and HF walnut shells.
Old May 13, 2017 | 07:23 PM
timski's Avatar
timski
Pics
Attached Thumbnails Walnut blasting time!-photo126.jpg   Walnut blasting time!-photo63.jpg   Walnut blasting time!-photo135.jpg
Old May 13, 2017 | 07:30 PM
Torquenut's Avatar
Torquenut
I was thinking small, think this will work or just go big or go home?
Old May 13, 2017 | 07:47 PM
timski's Avatar
timski
Well, I think you will be refilling that gun like every 2 mins. I had a really hard time controlling the flow of walnut shells. My setup was throwing a ton of shells. No matter what valve I adjusted I just couldn't slow it down. I ran at 90 psi. I think lower psi might have been better. I cleaned out my vacuum before starting and just reused the 5 lb of shells over and over. I did the whole job in about 30 mins. You need to find a setup that works for you. If you are under-powered in any way you might not be able to even start. Good luck.
Old May 13, 2017 | 08:12 PM
Torquenut's Avatar
Torquenut
great tips and I will try your way, thank you.
Old May 16, 2017 | 09:07 PM
f_p's Avatar
f_p
Gosh, that's indeed a lot of carbon built up.
I am having mine blasted. The car has 65 thousand Kilometers. I will post photos when received, to compare.
Old May 17, 2017 | 08:34 AM
vistaracer's Avatar
vistaracer
I did the carbon cleaning. After reassembly, car would not idle. I can hold the throttle pedal down and engine will run at 2000 to 3000, but as soon as I let off the pedal motor dies. I have three codes on EScan Gage- U114B, U115B, U115E, which according to Bentely manual are lost communication with engine control torque 1, lost communication with engine control torque 3, and lost communication with engine data. Anyone have any suggestions? It acts like a big intake manifold leak. I have double checked all the connections. I am at a lose.
Old Jul 12, 2017 | 11:03 AM
timski's Avatar
timski
Thanks. But now that I have money invested in walnut blasting equipment I will stick with that.
Plus over the long haul it's cheaper to walnut blast in my opinion. (I have 3 R56's).
