Need O2 sensor for '06
Old Apr 23, 2017 | 06:40 AM
audiodef's Avatar
audiodef
Check engine light came on in my '06. Plugged in my OBDC-II reader and the code is for the O2 sensor. A little checking tells me it should not be overly difficult to replace the sensor.
There are two, right? Should I replace both? Is it worth a DIY repair? I enjoy doing these things, but if I'm not really saving money over bringing it to my local garage, I kind of have a lot on my plate these days. They've quoted me over the phone as this repair costing, at most, somewhere in the $400 range - half that if it's the lessor of the two sensors that need replacing. (I forget if it's pre or post.)
Where is a good place to get this part?
Old Apr 23, 2017 | 06:48 AM
Cenla Mini's Avatar
Cenla Mini
There are a lot of good threads on the O2 Sensors...from what I've read the majority fo the problems are with the pre-cat sensor. Most folks seem to recommend the NTK O2 sensors. I got mine on Amazon but haven't changed it yet...mine has been a bear to get off and I'm waiting to change it by removing the exhaust manifold...when you do that though they recommend new bolts and of course a new gasket.
Old Apr 23, 2017 | 07:21 AM
audiodef's Avatar
audiodef
How much of a problem is it to continue driving once the car's OBDC says there's a problem with the O2 sensor? My preference of course is to get it fixed right away - I just want to know how much leeway I have.
Old Apr 23, 2017 | 08:08 PM
Cenla Mini's Avatar
Cenla Mini
I reset the warning on my wife's and it showed back up a few months after...to be honest I haven't seen any problems with it...it's just annoying but I'll get it changed eventually.
Old Apr 24, 2017 | 06:32 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Just for ha-ha's, ( get your mileage ) call your MINI dealer, ask for service department and see if they are covered. In some cases, they have extended the warranty on these for the 06 models....also seen issues with a re-occurring CEL for this issue which has yet to be resolved even after new manifold installed, but in that particular case it was bank 2.
No need to replace both at same time. They are also interchangeable ( same part both locations ) for purposes of diagnostics, but serve a different function due to location.
Old Apr 24, 2017 | 07:13 AM
Yep, check its right here. https://www.northamericanmotoring.co...o2-sensor.html
Might be out of the 10 yrs.
I believe bank 1 is the front and bank 2 is the rear if you have the code reader. I did one then about a couple months (the bank 1 went) later I did the other. That's why it might be easier to do both. Save you another fix.
Old Apr 24, 2017 | 07:41 AM
audiodef's Avatar
audiodef
I'm past 10/100k. I love how this car runs so well at this age.
ECSTuning, can you link me to the part I need?
Old Apr 24, 2017 | 08:11 AM
yep.
https://www.northamericanmotoring.co...om-up-top.html
Socket i liked using, in thread also UN1204250
