2012 mini Cooper s cranks but no start
Old Apr 18, 2017 | 07:03 PM
Hercules76's Avatar
Hercules76
I have a 2012 mini Cooper s with 95000 miles. Recently I have changed the fuel filter, low pressure fuel pump, the fuel rail pressure sensor, also changed the thermostat. Did all of that now it will crank but no start. I have spark. Put code reader on it an pulled up p0087- fuel rail system pressure too low. P10EE- fuel rail pressure sensor low bank 1. An all the codes for all cylinders misfire. Anything would be helpful. Thank you.
Old Apr 19, 2017 | 09:56 AM
AZdsrt's Avatar
AZdsrt
Sounds like the HPFP to me. Fortunately, Mini extended the warranty on the pump. I think it's 10 yr/100k miles..
Old Apr 19, 2017 | 11:55 AM
Hercules76's Avatar
Hercules76
I had it at the stealership. They said it was low pressure fuel pump. I know that doesn't mean nothing. But they did change the foot control modular.
Old Jun 2, 2017 | 12:53 PM
schovil69's Avatar
schovil69
What is the foot control module and why did they replace it?
Old May 24, 2022 | 05:09 PM
Davers's Avatar
Davers
Did it ever get sorted out ? We have the same symptoms
Old May 24, 2022 | 05:56 PM
Davers's Avatar
Davers
First item that was replaced 😞, OEM as well 😳
Old May 25, 2022 | 12:54 PM
MINIMI2's Avatar
MINIMI2
Look for JBE fuel pump relay, lot of information for testing and replacement. Total PIA if that' s the problem. It's hard wired in fuse box!
Old May 25, 2022 | 01:17 PM
Davers's Avatar
Davers
JBE Relay
I’ve been testing everything through Insta+ and was able to run the pump through the DME on the diagnoses scan so it seems the relay and pump work fine, does anyone know what triggers the fuel pump to prime when the door opens as that does not work since the problem started.
EnormousMini
Apr 28, 2017 10:46 AM
