Fuel Pressure issue:
Old Sep 9, 2019 | 07:57 AM
MCS_R56's Avatar
MCS_R56
I just replaced my HPFP on my 2012 MCS R56 which has the n18 engine. On random occasions the car will die and not restart. I clear the check engine light (says low fuel pressure) and I pull out the fuel pump fuse (which is never burnt out) and replace it. Then I go to start the car again and its like noting has ever happened to it and it runs perfectly fine. Anyone got any ideas or tips for me? Maybe a relay somewhere? not sure if it matters but my car also has 86k on it.
Old May 25, 2022 | 02:32 PM
Davers's Avatar
Davers
did you get this sorted ?
Old May 26, 2022 | 03:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I’ve seen cheap off-brand HPFPs fail shortly after being installed, and never being quite right fresh out of the box. For such a critical component, I would only consider either OEM Mini or a PSA fuel pump as a proper replacement. The cost certainly outweighs the hassle.
BHat1Trey
Nov 19, 2019 12:53 PM
MCS_R56
Sep 9, 2019 07:36 AM
JoelDB44
Jul 15, 2016 10:27 AM
MazMini
Mar 17, 2016 11:38 AM
