Drivetrain Cooling Kit
Old Mar 31, 2017 | 07:31 AM
Clutch Wotan's Avatar
Clutch Wotan
Cooling Kit
Cooling kit for MCS
Old Mar 31, 2017 | 06:11 PM
WhatV8's Avatar
WhatV8
Originally Posted by Clutch Wotan
Cooling kit for MCS
Specifically for what 'system'??
Old Apr 1, 2017 | 12:59 AM
Clutch Wotan
The cool pack is for B48/B46 Cooper S engines.
Old Apr 1, 2017 | 11:14 AM
Clutch Wotan
Cooper S standard frontend, note the airflow marks above the intercooler - good position
for remote radiator.
JCW 70 mm / Cooper S 60 mm charge air in/outlet - Its not only the core !
Attached Thumbnails Cooling Kit-bildschirmfoto-2017-04-01-um-13.59.08.png   Cooling Kit-img_2213.jpg
Old Apr 10, 2017 | 01:38 AM
Clutch Wotan
Finally installed. Proper installation I believe more efficient than Forge & Co, the developed remote radiator more efficient than the JCW wheelhouse solution.
I am very satisfied
Old Apr 10, 2017 | 07:22 AM
Clutch Wotan
Sleeper
Old Apr 11, 2017 | 11:16 AM
WhatV8's Avatar
WhatV8
I am very satisfied
So is the remote radiator (i.e.- above the intercooler) just for increased cooling system capacity of the engine coolant? Basically kind of like moving from a 1 or 2 row radiator core up to a 3-core unit for additional heat removal, correct?
Sorry for being a bit confused on the concept, just trying to wrap my old-school hot-rod brain around your upgrade. The intercooler upgrade I am good with, FWIW.
Old Apr 12, 2017 | 12:08 AM
Clutch Wotan
The approach is a PLug & Play Kit for increased power over 300 HP
The Cooper/Cooper S intercooler is changed to the +-25% more efficient JCW one, as the core height is higher you have to use the JCW Radiator as well, which has two additional ports for the remote version, the Cooper S don't have.
In order to make full use of the improved intercooler, you also have to use wider diameter charges hoses, for that i developed the following kit parts
1-Inlet flex - quickfit adaptor
2-Charge tube complete ( with alternative water injection).
So now you have installed the JCW Intercooler. In order to compensate the smaller radiator core, we choose a additional front mount radiator.
As the cooling of the turbo, is water and oil based, both regulated via the water temperature, it is crucial, why would MINI consider this with their expensive wheels house additional cooling ?
The whole issue makes only sense for F56 with over 270 HP and ECU tune, for the normal usage "Burger box" etc you fine with the factory system. additional intercoolers, except some custom versions, makes no sense in term of prices
and performance, as the JCW 13 rows is the best !
Old Apr 12, 2017 | 12:27 AM
Clutch Wotan
Important as well is obviously the airflow and its direction, shrouds and aero parts guarantee a free flow under the car, and through the motor compartment.
Old Apr 12, 2017 | 10:46 AM
WhatV8's Avatar
WhatV8
Ok, I have a clearer picture of what you have put together.
The only thing I question is placing the auxiliary radiator directly in front of the main radiator. All the heat rejected out of the aux radiator goes right into the main radiator, which in turn would reduce the overall efficiency of the system. I have a feeling this is the main reason the aux radiator in the JCW is in the wheelhouse, so it is in a different airflow path. Not sure if you are indeed getting the 'bang for the buck' with that aux radiator setup and it might just be enough to simply upgrade to the JCW radiator alone if you are not going for much over the 300hp mark??
Old Apr 12, 2017 | 12:44 PM
Clutch Wotan
I don't see that problem with that "buck" i put together
Old Apr 12, 2017 | 06:54 PM
WhatV8's Avatar
WhatV8
Probably isn't anything 'wrong' with the kit, just wondering if there is a real benefit to the additional radiator or if just the upgraded JCW radiator would be enough for say keeping things below 350hp?
It looks like you take your car to the track, so it would be neat to see the before/after temps running a similar amount of laps in as similar ambient air temps as you can find. I know it would be tough to get 'clinical' numbers on the test, but I would have to think you could get close.
Not knocking your kit, but I have seen too many 'smoke and mirror' claims out on the market without any evidence to back them up, so I always ask questions to satisfy my own curiosity.
Old Apr 12, 2017 | 09:37 PM
Clutch Wotan
You right, that the JCW radiator itself can do it. Considering that it has a denser fin pack, and the overall calculation includes automatic, hot countries.
But my solution looks hotter and will be for sure tested for the track !
Is the intercooler disputable and goes also under additional "catch tanks" ?
Would you buy a kit like that for +/- US 666 ?
OEM JCW/ Radiator ( supplied with 2 plugs to close)
OEM JCW Intercooler
Hose Kit
as option:
Remote Radiator with piping
Would you see a further "race-intercooler" option with higher depth 140mm on top of the jwc 120mm (Cooper S 100mm) as worth anything ?
Old Apr 20, 2017 | 01:21 PM
Clutch Wotan
ups - watch pos 2 they copy me !
Old May 5, 2017 | 09:41 AM
Clutch Wotan
Testet it the 1st time. When the pressure and temp reach a certain point it get "auto activated" and delivers a sudden delta bigger than 1o
Old Jan 31, 2018 | 10:15 AM
Clutch Wotan
As a matter of interest the remote radiator for the JCW has been deleted :-) the saved money goes into new 3D printed personal cup holders (MINI Yours)
https://www.mini-f56-forum.de/index....g/?thumbnail=1
A tricky move, makes tuning on JCW difficult, if nothing else (radiator core depth) has been changed the heat window becomes closer.
Bean0709
Mar 24, 2017 06:01 AM
hntsmith
Jan 23, 2017 04:59 PM
tvanhouten
Mar 1, 2011 05:21 PM
d_r_young
Jul 23, 2008 11:23 PM
RX93
Dec 17, 2005 08:37 PM
