P0301 code 2007 mini cooper S. R56
Old Mar 8, 2017 | 12:51 PM
Matt Byrd's Avatar
Matt Byrd
I have a p0301 code showing on my code reader. I changed out the knock sensor after the p0327 code showed. I checked the plugs they all look good. I swapped the coil from #1 cyl to #2 cyl. Code still comes back after being cleared. Any other ideas what might cause the misfire in #1 cyl. The car drives okay but you can feel the hesitation and then the code gets thrown after being cleared. All this started after I changed out the oil cooler gasket which was a real pain in the neck to do i might add. Thank you for help
Old Mar 8, 2017 | 01:09 PM
BigBoost's Avatar
BigBoost
when was the last
time the car was
carbon blasted ?
have you double check all the wire's
to make sure you didn't pull any thing
out when doing the
seal?
an when you swap the coil from 2 to 1 your still getting the misfire ? Did you check the plug'
Old Mar 8, 2017 | 03:51 PM
Matt Byrd's Avatar
Matt Byrd
Thanks for the reply. I haven't done the carbon blasting. What is the story behind that? I did swap the coils and the code still reappeared after doing so. The plugs all look good. They have a nice tannish color. I did not check the plug gap though. The plugs are newish, replaced in the last 8 or 9 months. None of the wires look out of place since the oil cooler gasket replacement.
Old Mar 8, 2017 | 04:47 PM
BigBoost's Avatar
BigBoost
so basically what
happens with
Direct Injection car's
is the intake valves have nothing
spraying on them to cool the valves down
over time the valves start to cook them self
an carbon starts to builded up on them
got this photo from google
mit be worth getting a hold of
a dealer
before bigger problems start
very commen problem with the r56
Old Mar 8, 2017 | 04:58 PM
AZdsrt's Avatar
AZdsrt
What year and how many miles? Might also be time to do a compression test..
Old Mar 8, 2017 | 06:02 PM
Matt Byrd's Avatar
Matt Byrd
It is a 2007 mini cooper S. It has approximately 140,000 miles.
Old Mar 8, 2017 | 06:12 PM
AZdsrt's Avatar
AZdsrt
High mileage n14 engine, my bet is on either carbon on the valves (as bigboost mentioned) or low compression. Fortunately both are easy to confirm. If you're lucky, it's carbon build up..
Old Mar 20, 2017 | 08:23 AM
Matt Byrd's Avatar
Matt Byrd
How does the carbon blasting get taken care of? Does Seafoam do the trick. Thanks for any help
Old Mar 20, 2017 | 09:38 AM
AZdsrt's Avatar
AZdsrt
The intake manifold is removed, then the valves and intake chamber is blasted with walnut shells. Common problem on the n14 engine. And nope, Seafoam won't help as these are direct injection engines..
