R60 Rear Wheel Bearing Hub Assmbly
Old Mar 5, 2017 | 09:27 AM
KoolAide's Avatar
KoolAide
R60 Rear Wheel Bearing Hub Assmbly - SOLVED
I could use a little help. I have been unable to find the torque specs for the four bolts that hold the rear wheel bearing hub assembly. The hex bolt head size, in socket measurements, is 18mm. These are the four bolts that hold the complete wheel bearing assembly to the car. I made the mistake of thinking the rear caliper bracket was held on like the front and just went to town taking bolts off. well, oops. So now I have two of the four bolts I need to re-torque.
thanks
kool-aide
Old Mar 8, 2017 | 05:11 PM
KoolAide's Avatar
KoolAide
still looking for help, thanks. I even called Chilton tech support. we are stumped. I posted on another site, still out of luck.
Old Mar 9, 2017 | 04:24 PM
KoolAide's Avatar
KoolAide
help from cristo on this one, thanks
Rear wheel hub to trailing arm (M10x35mm) 56 Nm, 41 ft-lb
Old May 7, 2023 | 02:42 PM
gstilphen's Avatar
gstilphen
Correct info from TIS
I'm aware this is an ancient thread, but in case anyone stumbles across this thread, official torques and parts from Mini TIS:
Hub to trailing arm: 100 Nm
(Torque crosswise like an X pattern)
Axle nut to hub: 182 Nm
And the bolts are not M10x35. They are M12x1.5x60 grade 10.9 with factory red loctite
NealDePape
May 7, 2023 02:51 PM
CSIavarone
Aug 27, 2012 08:34 AM
nkatsim
Oct 31, 2010 07:43 PM
investigator
May 10, 2008 11:14 AM
