F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Retrofit illuminated door trim
Old Feb 15, 2017 | 05:12 AM
tmehanna's Avatar
tmehanna
Anyone knows if the illuminated front door trim is retrofittable without replacing the entire front door trim assembly?
Old Feb 18, 2017 | 06:19 PM
bratling's Avatar
bratling
Super Moderator
May be possible. On the F56/55 the wiring for the illuminated door trim lights is already present and the lighted trim can be retrofitted. I haven't dug into the F54 parts diagrams but the front door isn't that much different so it may be equally simple. Learn more at this thread:
https://www.northamericanmotoring.co...long-door.html
Old Feb 19, 2017 | 12:42 AM
tmehanna's Avatar
tmehanna
Thank you. I believe the F54 is different because it's the actual trim that lights up and not an additional LED strip under the trim like in the F56. I also couldn't find part numbers for the door trim pieces regardless if illuminated or not, only complete door panels, so looks like they are not removable from the door panels.
