Coil Replacement
Old Jan 5, 2017 | 08:43 AM
Old Eagle's Avatar
Old Eagle
Coil Replacement
Has anyone needed to replace their coils? It seems mine all went bad at once. Seems a little fishy to me.
Details:
2011 Cooper S
about 69K
all stock
Old Jan 5, 2017 | 08:52 AM
minirab's Avatar
minirab
I've had one go bad on my 12 JCW but only one.
Old Jan 5, 2017 | 09:38 PM
renchjeep's Avatar
renchjeep
I had two that were failing intermittently all at once on my 2011 MCS. My aftermarket warranty company authorized replacing all 4 coils, if the MINI dealer could get all 4 cylinders to show misfires. The dealer swapped coils around, got all 4 cylinders to set misfire codes. (Maybe they just unplugged the other 2. LOL.) Hendrick Autoguard authorized 4 new MINI coils to be installed, and my $100.00 deductible somehow turned into only a $48.00 charge from my MINI dealer. And, I got a free loaner MINI from the dealer while they did the diagnosis and repair. Pretty cool!
Old Jan 15, 2017 | 11:44 PM
lemarzmini's Avatar
lemarzmini
Did you get a CEL code for all 4 cylinders?
Old May 25, 2017 | 09:30 PM
seandallen's Avatar
seandallen
Details:
2011 Cooper S
about 69K
all stock
You should replace them all at the same time, regardless. It is a VERY simple job. Buy the coils online, and do a youtube search on how to do it.
Old May 26, 2017 | 01:07 PM
JohnPlayer's Avatar
JohnPlayer
I've had 2 go out in the past, had them both replaced. I replaced all 4 in the past month because I was having issues that turned out to be the HPFP but at around $100 for all 4 I figured it was an easy thing to do in order to rule those out.
Old May 27, 2017 | 05:52 AM
sikamini's Avatar
sikamini
I have. Replaced all four about three years ago.
Old May 27, 2017 | 11:05 AM
usmc_mitch's Avatar
usmc_mitch
Suggestions on where to purchase online? Or go to local AutoZone? I imagine since our systems are super sensitive that aftermarket isn't the best...
Also gonna do plugs and coils at the same time.
Old May 27, 2017 | 12:01 PM
BXR's Avatar
BXR
I had one coil replaced. Should I replace the other three?
