R50/53 MCS. Do your Revs go down when you put clutch in?
This may be a strange question to those who dont have this problem:
You need a stick shift for this to happen obviously.
While moving, when you put your clutch in, to change gear (travelling at any speed), how long does your RPM stay at its current spot before coming down.
I have a 2004 MCS, and it takes probably a full second before the revs actually start coming down after I put the clutch in. I actually like this, but it occured to me that maybe not all S's are like this, and it might not be normal.
Can anyone else confirm? Also, is there anyone that has this "problem" AND the new v.XX software?
Get the MTH ECU upgrade and this is much less noticeable. Oh, and you get a lot more power to boot.
Thanks for all the feedback.
So, if I'm the dissenting opinion in here and I think it totally sucks, what are my best options for improving the situation?
How much of this lag is due to physics (a heavy flywheel) and how much of it is because of ECU intervention?
R50/53 How to remove rev limiter??
Josh572
Aug 22, 2015 03:02 PM
R50/53 Replacement AC compressor??
PrimePower
Aug 16, 2015 06:29 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
