R60 2012 Countryman Halogen to LED swap?
Old Oct 30, 2016 | 05:07 PM
abenson5697's Avatar
abenson5697
I have a 2012 Countryman with Stock Halogen Lights and am looking to upgrade to LED's. Lumen has a set coming out in a week that have a fan and load resistor built in.
https://www.carid.com/2012-mini-coun...175099785.html
Didn't know if anyone knew if these will fit behind the dust cover on the stock headlights and if they will work without programming. I tried doing an HID kit on my car but the dealer that was going to order and install the lights said that it will not work on my car because of the computer system and the design of the headlight having the dust cover and what not.
Thanks!
Old Dec 11, 2016 | 08:30 PM
dcttrs's Avatar
dcttrs
Did you ever end up installing an LED kit? I was considering the slightly cheaper G7 kit but was also hoping to find somebody else who's already confirmed that they fit on the Countryman, and they don't produce any errors.
Update - Figured out that I can't use these after-all. They aren't DOT approved so they won't pass annual state inspection where i live.
Old Dec 12, 2016 | 12:38 PM
Chad Morin's Avatar
Chad Morin
I have a 2014 Countryman with stock lights. Ebay has kits all over the board claiming fitment for $75 cheaper than ECS. I chose ECS because of the piece of mind that support will be in eluded and the kit was customized for my exact vehicle. My believe is that the Ebay bulbs could possibly the same manufacturer as the ECS kit but will they all be? Will some not fit? What do you do if the cheaper bulbs throw codes? You won't get support from some Chinese warehouse, let alone the availability to exchange partial items if needing a return. I looked at it this way. Good bulbs $30 Ability to Return $30, Customer support $20, Easy instructions on how and where to instal $20. ECS had all that.
Old Dec 12, 2016 | 01:50 PM
Thanks for the purchase of Ziza and we have the install PDF, and have installed / tested them. Also if you have a problem we are here to help and MINI people.
Just want to give you guys a heads up. We now have halogen => projector LED DRL headlights from spyder. These are in the F60 design for your R60/ R61. They are just like the halogen spyder ones fro the R56-R59 but these are for the R60 Countryman / R61Paceman. No Xenon to Xenon version yet.
But these take halogen H9 bulbs ( or if you want to do your own xenon/ led retrofit H9) Bi-halogen. This means they have 1 bulbs that has a flap like the Xenon factory system and when you use the highs, the flap moves up.
Bottom turn signal is standard P21 bulbs and this system is plug and play.
Sold as a Set:
PRO-YD-MCO11-DRL-BK
https://www.ecstuning.com/Search/SiteSearch/ES3188142/
Old Dec 19, 2016 | 04:32 PM
PtMini's Avatar
PtMini
Sold as a Set:
PRO-YD-MCO11-DRL-BK
What the.., I so want these.
Old Dec 20, 2016 | 04:53 AM
Welcome,
Here is better pics of the set without the led DRLs lit.
Old Dec 20, 2016 | 09:26 AM
techgearpro's Avatar
techgearpro
That kit looks great! I'd like to see it installed on a ECS or NAM member Countryman. I'm especially interested in this with a good LED bulb kit. I'd like to see this vs the stock halogen side by side up on a wall showing the beam patterns.
Old Dec 20, 2016 | 10:37 AM
Yes they do. Hopefully in the short future we will have install pics. These just came out.
Old Jan 1, 2017 | 10:54 AM
MannyJimenez's Avatar
MannyJimenez
Anyone install these on their R60? Post pics please
Old Jan 1, 2017 | 11:13 PM
Centium's Avatar
Centium
I had the equivalent Spyder set installed on my R56S before I traded it. The LED portion looks outstanding, and I was able to upgrade the projectors to an aftermarket HID kit (with anti-flicker harness). It was OUTSTANDING and in my opinion, better than the Mini Bi-Xenon headlamps. The cutoff was crisp and the installation and adjustment was simple.
These lights are made by the same manufacturer, and most likely offer the same quality. If you want a Bi-Xenon upgrade for your R60, these headlights and the HID kit in the link below are the solution. It will be 1/3 the cost of what Mini wants for the same job and you can easily do it at home.
https://www.amazon.com/gp/product/B004ZF4MW8
https://www.amazon.com/gp/product/B00HTOB0NG
Old Jan 17, 2017 | 05:52 PM
techgearpro
808keith found so photos and posted them to this thread https://www.northamericanmotoring.co...ml#post4269012
ECSTuning,
Do you know if the amber is only on when the blinkers are activated? How about the DRL? They almost look like they are wired into a relay so I'm wondering if they dim or are disabled when the headlights or blinkers are on.
Old Jan 17, 2017 | 05:58 PM
MannyJimenez
ecstuning,
do you know if the amber is only on when the blinkers are activated? How about the drl? They almost look like they are wired into a relay so i'm wondering if they dim or are disabled when the headlights or blinkers are on.
linked
Originally Posted by 808keith
finally found pics of these on a countryman
Old Jan 17, 2017 | 06:15 PM
techgearpro
And there is a Youtube of the lights not installed.
Old Jan 18, 2017 | 05:28 AM
ECSTuning,
Yep, just saw that. They are on when you turn the Turn Signal on or the hazard light, they will flash for those lower amber bulbs.
Old Jan 18, 2017 | 05:48 AM
Centium's Avatar
Centium
The ambers are turn signals. The LEDs are wired into whatever you choose. On my R56 I wired them into the parking lights so the LEDs would come on instead of the parking lights due to the fact that I installed projector fog lights.
Old Jan 18, 2017 | 05:52 AM
+1 I have the additional wires ( DRL Halo) on my R58 Spyder head light wired into my position lights.
Old Feb 6, 2017 | 08:49 AM
techgearpro
Beam patterns for Stock Halogen vs Spyder Projector headlights
Stock halogen lights - Low beam
Stock halogen lights - High beam
Spyder projector lights - Low beam
Spyder projector lights - High beam
This photo shows best how the projector headlights light up more of the road. I had positioned the MINI so the stock halogen lights would just cut off at the bottom of the door.
Old Feb 6, 2017 | 10:59 AM
techgearpro
More photos of beam pattern
The marks on the garage door are blue painters tape to show the top and center of the previous headlights. I've since adjusted the left side to centered it back to the right.
Spyder Projector - Low beam (exposure adjusted to better show pattern)
Spyder Projector - High beam (exposure adjusted to better show pattern)
Old Feb 6, 2017 | 11:25 AM
techgearpro
Which wire colors should I tap if I'd like to tie them into the top half of the existing DRLs on a 2015 Countryman? Also, is the green wire the ground on the LED DRL?
Old Feb 6, 2017 | 11:29 AM
On the spyder its the black-ground, green positive. On the position lights only or the position lights/ fog light combo, it's those top wire to the position lights tapped into. On MINIs with factory LED DRL Fogs or the MINI factory retrofit you will have to get a voltmeter and see which wires energize as that's a coded system and I did not have those.
Old Feb 9, 2017 | 08:03 PM
techgearpro
Halo on or off at night?
I have a '15 MINI Countryman with the LED DRL Fogs. I figured out which wires to tap:
Spyder black wire --> MINI brown wire
AND EITHER
Spyder green wire --> MINI yellow wire with green stripe (on as DRL but off with headlights)
OR
Spyder green wire --> MINI black wire with green stripe (on with position lights and with headlights, off with DRL)
NOTE: The above wire is on the driver's side, the passenger's side is white with blue stripe.
Are the halos intended to be on or off at night with the headlights? They seem pretty bright and look like they would be generating plenty of glare for others and myself in bad weather at dusk and evening.
Thanks!
Last edited by techgearpro; Feb 11, 2017 at 06:04 PM. Reason: Added details since the passenger's side wire was a different color.
Old Feb 10, 2017 | 05:23 AM
Thanks for posting that info on the factory DRL/fog connections.
Halos are intended to be on with the headlights, and they can be either on with the head lights off and ignition on or come on with the parking lights. Yes they do throw off light like the R56 version, but they dont glare at all. The new F56 and F60( which I just saw in person) are more concentrated and brighter than these. And other factory OEM DRL for of car companies are much brighter. Like you can see at night with just the DRL on some cars The ones on the Tesla's are super bright.
Old Feb 11, 2017 | 06:51 PM
techgearpro
Photos showing the lights installed and hooked up
Lights off
DRLs only
DRLs and position lights
Position lights and headlights
Parking lights
Old Mar 14, 2017 | 05:10 PM
techgearpro
Did anyone else purchase and install the Spyder PRO-YD-MCO11-DRL-BK headlights?
Old May 1, 2017 | 06:16 PM
techgearpro
An update on these lights as I have noticed that ECS is no longer selling the Spyder-branded version but now show it under the Sonar name.
After installing and troubleshooting two sets of headlights with Spyder directly, I ended up returning them as I had the same problem with both sets. In low temperatures, the solenoids that activate the high beams would start to vibrate. You could hear them quickly activating and deactivating as well as see the low beam shield fluttering the light on my garage door. Spyder was unable to provide a solution or recommendations for further troubleshooting. The reseller was very helpful and responsive and I would gladly buy from them again in the future.
