Interior/Exterior Installed Driving lights
Old Oct 9, 2016 | 03:04 PM
Squirrel724's Avatar
Squirrel724
I installed a pair of driving lights on my R50 the other day. The car looks great with a pair of Hella 500s mounted on to factory light brackets. They work great and while they do bounce a bit because the Hellas are heavier than the Mini lights you don't notice it while driving. And it looks so proper with a pair of lights.
Please ignore my ugly hood. The paint is completely shot and needs to be resprayed at some point.
Old Oct 9, 2016 | 05:47 PM
BlwnAway's Avatar
BlwnAway
I'm in total agreement, the larger driving lights look so much better on a Mini than the stock ones, even in the stock location.
Old Oct 9, 2016 | 07:41 PM
Racingguy04's Avatar
Racingguy04
I like em! I keep thinking about putting some on mine, but still haven't pulled the trigger. Did you wire them in like the OEM setup? or just follow the Hella instructions? where'd you put the switch?
Old Oct 10, 2016 | 05:21 AM
mdaz75's Avatar
mdaz75
I'm liking addition of driving lights the more I see them. Can you post a few more angles?
Old Oct 10, 2016 | 06:02 AM
Squirrel724
I wired them per hella's instructions such that they can only be on when the high beams are on. The switch is mounted into a storage tray I got from an 2005 or 2006 Cooper which is mounted under the switch panel.
Old Oct 11, 2016 | 07:17 AM
qolor's Avatar
qolor
hella 500ff on oem brackets also
Old Oct 11, 2016 | 09:02 AM
Squirrel724
Looks great! I got the standard 500s for mine. I honestly thought they were going to be a bit large for the car but they look perfect once they are on there.
Old Oct 11, 2016 | 09:28 AM
dpunisher95's Avatar
dpunisher95
I got PIAA lights on mine and pretty happy with them, they have been on for 3 years and they are holding up strong.
Old Oct 11, 2016 | 10:01 AM
Squirrel724
The PIAA lights were my ideal choice but they cost almost 5x as much as the Hellas.
Old Oct 11, 2016 | 10:29 AM
Jimmyjamesphan's Avatar
Jimmyjamesphan
One of the first thing I got was the PIAA fogs and I love them too
Old Oct 11, 2016 | 10:31 AM
dpunisher95
True, they are worth the money if can get them.
Old Oct 11, 2016 | 10:32 AM
Jimmyjamesphan
Only cost me 100 bucks with brackets
Old Oct 12, 2016 | 05:44 AM
MiniTigger's Avatar
MiniTigger
Where you located .. Frederick County here.
Old Oct 12, 2016 | 07:09 AM
qolor's Avatar
qolor
over here in cape in annapolis
Old Oct 12, 2016 | 01:11 PM
MiniTigger's Avatar
MiniTigger
Loving the off to the side plate mount. Also love the driving lights. . Did you wire them up?
Old Oct 12, 2016 | 02:02 PM
qolor's Avatar
qolor
thank you and thank you. i work on MINIs for friends if you need work. i usually only do R53s.
yeah - theyre all of my aux lights are wired to their own relay *a single one* that is a 40amp Morimoto. I have 4 relays for my high and lowbeams. each of them get their own relay for reliability reasons. high and low are 55w HID, hellas are 100w halogens right now, got 75w HID ballasts coming and i'll see if it melts the housings.
I also have a hidden light bar under the tiny middle grille
Old Oct 26, 2017 | 09:54 AM
ApexinM3's Avatar
ApexinM3
Resurrecting an old thread here: I have the OEM kit and will be installing the brackets soon; can anyone with the hood mounted lights show me their brackets on the underside? Mine looks like the grille needs to be removed for access (I have the stock grille) and when I checked it the tabs look as though they will break on removal.
Old Oct 26, 2017 | 11:58 AM
pmanliu's Avatar
pmanliu
Grill doesn't need to be removed to install brackets. And yes, the tabs on the grill royally suck and ill be surprised if individuals got more than 1 use out of them. I ended up just pulling the nuts off and using 3m double sided tape to secure the grill.
Old Oct 26, 2017 | 07:00 PM
I'mMelting's Avatar
I'mMelting
PIIAs on my Jeep and Minis on my Mini!
Old Oct 27, 2017 | 05:47 AM
Nice!
Old Oct 27, 2017 | 10:23 AM
optikon's Avatar
optikon
WIPAC here
Work with high beams and also you can turn them on by the switch, also without any lights ... Just driving lights On standard bracket
Old Oct 30, 2017 | 08:08 AM
RedAggie03's Avatar
RedAggie03
Is there a good source for the factory brackets?
or a good aftermarket alternative?
Old Oct 30, 2017 | 08:32 PM
CDUBL's Avatar
CDUBL
I opted for this set. Cant beat $45 https://www.outmotoring.com/mini-coo..._brackets.html
Old Nov 1, 2017 | 04:29 PM
CRC's Avatar
CRC
https://www.ebay.co.uk/itm/Stainless...item53fb8bf555
This company in the U.K. has stainless steel brackets on e-bay for about $38 shipped.
Old Nov 9, 2017 | 07:00 PM
KevinR's Avatar
KevinR
My 500s bounce too much for my liking. I am probably going to ditch the hood brackets for some kind of bumper mounted bracket. Here is how the car looks right now:
