help with DTC codes please
Old Oct 3, 2016 | 08:40 PM
Lynkdev's Avatar
Lynkdev
Hi, new to the forum...have a 2011 mini non S convertible and have a check engine light and cant seem to find these codes pulled by firestone:
272F (fuel tank ventalation?)
5E56
A0B0
A6A3 (hydraulic fluid temp sensor?)
These are mini specific DTC codes?
any help please?
Old Oct 4, 2016 | 06:05 AM
MiniToBe's Avatar
MiniToBe
clear the codes and see if they return...make sure your fuel cap is tight and dont fill gas while car is running (if you do that, if not, ignore )
Old Oct 4, 2016 | 11:57 PM
Lynkdev's Avatar
Lynkdev
How do i clear the check engine light and DTC please?
Old Oct 5, 2016 | 04:40 AM
MiniToBe's Avatar
MiniToBe
you need a scan tool that can clear the codes. you may get a universal one so you can use it on other cars.
Old Oct 5, 2016 | 08:41 PM
Lynkdev's Avatar
Lynkdev
Ok thanks, and just to confirm..this DTC wont clear itself if it was the gas cap and now its on tight?
Old Oct 6, 2016 | 03:16 AM
MiniToBe's Avatar
MiniToBe
It can clear itself but only when it goes through a cycle of maybe 35 miles. We wanted to clear it by scan tool to see if it comes back or new codes come out.
Old Oct 8, 2016 | 03:41 PM
Lynkdev's Avatar
Lynkdev
The check engine light cleared while driving it to BMW this morning after making sure the gas cap was tight a couple days ago after filling up. Hopefully this was the issue.
After taking it to BMW today for an oil change and check out they tell me my left rear taillight assembly needs replacement costing 250 and i have a small oil leak (location added later once i go pick it up). I don't understand how i could have a leak if i have no evidence of it on my garage floor. Do these cars have common leaks?
Also going to try to fix the taillight assembly myself later today. Looks like a burn mark around where the bulb seats could be the culprit from what the service guy said. I can probably clean it to make better contact.
Old Oct 8, 2016 | 05:38 PM
AZdsrt's Avatar
AZdsrt
If a small leak, may not make it to the garage floor. And yep, Mini's are known to leak in a variety of places. Did they tell you where it is? Chances are it'll get worse over time, pay 'em now or pay 'em later..
Old Oct 10, 2016 | 12:49 PM
Lynkdev's Avatar
Lynkdev
They said drive train area but didn't specify lol.
Another thing I noticed is when i accelerate in overdrive up a hill or on the hwy i get a Smokey engine smell through my ac vents.
The intake for the ac is below the window wipers correct? What would cause this? Gasket on hood looks just fine.
InnocentiMini
Dec 30, 2016 06:13 PM
cb_smalls
Sep 1, 2016 12:29 PM
Ernie Orwig
Aug 16, 2016 08:30 PM
Ernie Orwig
Aug 12, 2016 06:14 PM
Nicbay350
Aug 10, 2016 08:18 AM
