Electrical Coding cruise control retrofit with NCS expert?
anyone coded bc1 to enable MFSW/cruise control?
I just finished my wiring/control/clockspring retrofit now I need to code the ECU, hoping I can do this with NCS expert
So my wire showed up. I have all the parts to install now. Just having trouble refinishing the steering wheel pieces. whatever. I thought I would never see the wire. Were you able to get it programmed via NCS expert? or did you have to go to the dealer?
both clusters are canbus it's just a parameter that the kombi module uses, I dont think that'll be an issue
I think facelift have slightly different wiring and I'm not sure what to do next
I checked my plug at the black plug. The one in the car is green. And all the wires need to be swapped. The 2 pins are free. I have it all sorted out except the facelift clutch switch. The directions I have are in German and there is already a clutch switch on the clutch master cylinder. I might just use the pre facelift switch and build my own bracket to trigger it. My old prefacelift car which has cruise control doesn't have a clutch switch but does have a sensor on the master cylinder. So confused.
Jarvistech
R55 :: Clubman Talk (2008+)
16
Apr 8, 2017 03:02 PM
R50/53 Ecu reflash yes or no
50shadesofr53
Sep 8, 2016 06:29 AM
