R56 ScanGauge or Ultra Gauge?
I can't stand not knowing at least the water temp in my 07MCS and I'm looking for an efficient and low-cost method.
I ran across these two items and seeking opinions from an actual user standpoint.
Thanks.
Thanks.
I have purchased and used both in my 07 base model and 06 JCW. The ultraguage quit working in my 06 after a year or so of use, the scanguage is still going strong in the 07 after 9 years. I now have a scanguage in each car.
While it was working were you able to monitor coolant temperature and maybe boost?
Do you wish for traditional gauges or are you satisfied with the OBD2 gauges?
Scangauge for sure. I have one in each of my cars and love it. Plus we send them preprogrammed with the extra MINI specific codes so you can get oil temp on an 07, the newer cars have a few more things including oil pressure.
https://www.waymotorworks.com/scangauge-ii.html
Thanks for all previous answers.
ScanGauge is currently closed.
I have version 4.2 and the version needed to get XGauges is 4.13G2.
Will I have to downgrade my version to 4.13 or the XGauge stuff will already be in 4.2?
Thanks.
Thanks.
I've got an ultra gauge from a previous car around somewhere, worked fine for a few years and 100k miles. Only issue was every once and a while something would go askew and I'd have abunch of negative values. Dunno would just unplug and reset everything it'd be fine.
Now I use a obd2 bluetooth adapter (25$) torque app (5$) and tablet(tab s 8.4, obviously this can be something way cheaper) and mount (20$) to monitor everything
PelicanParts.com
Sep 28, 2016 08:35 AM
R50/53 Putting car on jack stands
Photodesign
12
Sep 25, 2016 08:03 PM
cargusjoh
Sep 22, 2016 08:29 AM
PelicanParts.com
Car Care Products
Sep 21, 2016 10:06 AM
