Interior/Exterior No Holes License Plate Bracket
Old Sep 17, 2016 | 01:32 PM
jmedina94's Avatar
jmedina94
Hi everyone:
My newly purchased R53 is currently in the shop for a new valve body but I am thinking about buying this no holes license plate bracket when I get her back. https://www.amazon.com/Cooper-HOLES-.../dp/B00F8O9ESC
How does this look? Unfortunately I live in a state where a front license plate is required. Sure looks better than drilling holes though.
Thanks!
Old Sep 17, 2016 | 02:19 PM
MINIAC's Avatar
MINIAC
This looks a lot more robust than the original GoMiniGo "No Holes" bracket I've had on my 2002 MCS for 14 years.
Cheaper than the Platypus from Cravenspeed.
Old Sep 17, 2016 | 02:48 PM
jmedina94's Avatar
jmedina94
Thanks! I will most likely order it. Can't wait to get the car back! The F55 (I think) loaner I have has a nice smooth ride but I totally miss my R53.
Old Sep 17, 2016 | 02:59 PM
Capt_bj's Avatar
Capt_bj
if you are the least bit handy you can make one for about $10 in bits from ACE Hardware. Start with a BIG bolt that matches the diameter and thread pitch of the towing hook .... you want something 4 inches long or so. Then a couple of washers and nuts .... maybe a flat piece of metal to form a backing plate.
Easy!
I decided to move to a no front plate state however ....
Old Sep 18, 2016 | 08:16 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Another option would be the Cravenspeed one as it works well and easy install
https://www.waymotorworks.com/craven...te-holder.html
Old Sep 20, 2016 | 04:55 PM
HaltCatchFire's Avatar
HaltCatchFire
You can also get a twofer on the Craven tow hook and fab a plate from some mild steel to reuse the stud - super easy, just cut a tab to angle it and drill the mounting holes. On the track/show just pop off the plate and install the hook - no need to unthread the stud, so you can locktite it solid.
Old Oct 1, 2016 | 10:48 AM
jmedina94's Avatar
jmedina94
Thanks, everyone. As an update, I ended up just buying the Platypus one on Amazon because I am not the most handy. Sounds like it won't arrive until Wednesday but that is fine considering my plates haven't even arrived yet.
Also ordered a set of floor mats that should arrive today.
The car is running much better than before. Replacement valve body seems to really help.
Old Oct 2, 2016 | 05:26 PM
David.R53's Avatar
David.R53
Fwiw, the tow hook is a weird metric acme thread. Virtually impossible to correctly match at your local hardware store.
rduffner
Jan 30, 2022 02:58 PM
ojannen
SCCA Solo and ProSolo
59
Sep 11, 2018 05:50 AM
JBC4317
May 25, 2017 08:04 PM
nosliwnaes
Sep 16, 2016 02:51 PM
jeffl
Sep 13, 2016 04:31 AM
