Drivetrain Manic tune and CEL
Old Sep 15, 2016 | 03:41 PM
roadrunner255's Avatar
roadrunner255
Manic tune and CEL
Hello all,
I have a gp2 with a Manic tune stage and when running agressive get the CEL. Anyone else have this?
Usually goes away the next time I start the car.
Cheers
Old Sep 15, 2016 | 03:45 PM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by roadrunner255
Hello all, I have a gp2 with a Manic tune stage and when running agressive get the CEL. Anyone else have this? Usually goes away the next time I start the car. Cheers
Are you running the stock spark plugs?
mQubed Motorsport, Manic Tuning Dealer
Old Sep 15, 2016 | 04:55 PM
roadrunner255
No, running the recommend plugs. NGK (1422) ILKR8E6
Old Sep 15, 2016 | 10:04 PM
GEMSTER's Avatar
GEMSTER
What's the code?
Old Sep 16, 2016 | 10:07 AM
roadrunner255
Originally Posted by GEMSTER
What's the code?
FYI I have a catless dp installed and
I did install the catless DP and NM engineering hi flow air intake box 658858 and their turbo hi flow down pipe 488856 before the tune was installed.
Cheers!
36BE
Coding: no variant
Error will not cause a warning light
Error is currently present
Test conditions have been completed
2D20
Oxygen sensor behind catalytic converter, electrical: intercore short circuit or oxygen sensor contaminated
Error will cause a warning light
Error is not currently present
3106
Catalytic converter: efficiency below limit value
2C57
Charge-air pressure control, lower value: charge-air pressure too low
2905
Intake-air system: suspected leak between turbocharger and inlet valves
spoolenturbo
GP Talk (2006)
Nov 27, 2016 12:40 PM
Dv8
Sep 30, 2016 11:16 AM
roadrunner255
Sep 15, 2016 02:17 PM
TWISTER
Sep 15, 2016 08:37 AM
MiniInTheSprings
Sep 9, 2016 11:21 AM
