Manic tune and CEL
Hello all,
I have a gp2 with a Manic tune stage and when running agressive get the CEL. Anyone else have this? Usually goes away the next time I start the car. Cheers |
Originally Posted by roadrunner255
(Post 4243748)
Hello all, I have a gp2 with a Manic tune stage and when running agressive get the CEL. Anyone else have this? Usually goes away the next time I start the car. Cheers
mQubed Motorsport, Manic Tuning Dealer |
Originally Posted by MarioKart
(Post 4243749)
Are you running the stock spark plugs?
What's the code?
Originally Posted by GEMSTER
(Post 4243842)
What's the code?
I did install the catless DP and NM engineering hi flow air intake box 658858 and their turbo hi flow down pipe 488856 before the tune was installed. Cheers! 36BE Coding: no variant Error will not cause a warning light Error is currently present Test conditions have been completed 2D20 Oxygen sensor behind catalytic converter, electrical: intercore short circuit or oxygen sensor contaminated Error will cause a warning light Error is not currently present Test conditions have been completed 3106 Catalytic converter: efficiency below limit value Error will cause a warning light Error is not currently present Test conditions have been completed 2C57 Charge-air pressure control, lower value: charge-air pressure too low Error will not cause a warning light Error is not currently present Test conditions have been completed 2905 Intake-air system: suspected leak between turbocharger and inlet valves Error will not cause a warning light Error is not currently present Test conditions have been completed |
