R53 pistons and rods?
Old Sep 12, 2016 | 05:01 PM
jeffl's Avatar
jeffl
So I have my 05 S engine at the machine shop getting the crank turned and the rods recon'ed. They called and said crank is good but will be 10 under. The bad is 3 rods out of 4 are junk and the pistons to. Why would I need to get new pistons if only the rods are junk?
Old Sep 12, 2016 | 06:24 PM
xsmini's Avatar
xsmini
Sounds like you stated the pistons are junk too. Did I read that correctly. I'm curious what happened to your engine. What oil you use, and oil change interval. I just finished (9,000 miles ago now) rebuilding my S, and at the time it had over 365,000 miles on it. All my rods showed no wear, as well as the crank. Neither required any machining.
Just curious to hear your maintenance routine vs mine.
Nik
Old Sep 12, 2016 | 06:59 PM
jeffl's Avatar
jeffl
They didn't say the pistons were junk. Just that I would need to get new ones, but I could have misunderstood them. I call them back tomorrow. I bought the car not running at a car auction. It didn't run. The timing chain guides were junk. So I put a timing set in it. I managed to get it running once, but it rattled like crazy. I didn't discover the destroyed rod bearings until after I pulled the engine and took apart. I never would have thought spun bearings in a car with less then 50k on it. Whats sad is I bought another engine off craigslist and it has the same problem. I kick myself every day for not pulling the pan when I bought it. So now I'm just want to get it back together without wasting anymore money. Maybe I can part out the other engine.
Old Sep 12, 2016 | 07:02 PM
jeffl's Avatar
jeffl
I don't think the PO had any maintenance routine.
Old Sep 12, 2016 | 07:12 PM
xsmini's Avatar
xsmini
Ah, ok. I've been following your other thread, but didn't make the connection
My guess would be that they are showing some kind of damage that they aren't comfortable putting back into the car. The machine shop should be able to explain there reasoning. If everything measures up, and there is no honing required, I would think you should be able to get parts off the donor engine.
Sorry to hear about all your troubles.
Nik
Old Sep 13, 2016 | 04:31 AM
jeffl's Avatar
jeffl
I sure hope so.
RedCountryS
22
Nov 15, 2020 04:34 PM
15sharpie
Oct 18, 2019 06:37 AM
RedCountryS
R60/R61 Stock Problems/Issues
Jan 1, 2017 08:11 AM
Tommy Kardinal
Sep 8, 2016 02:42 PM
SneedSpeed
Sep 7, 2016 08:51 AM
