Clutch pedal engage/disengage point
Old Sep 6, 2016 | 08:16 PM
cargusjoh's Avatar
cargusjoh
My 2011 R55 clutch pedal engages/connects the engine and transmission at the very top of the pedal travel. I think my previous (2012 R55) engaged lower down. Is this a cause for concern?
Thanks!
Old Sep 7, 2016 | 06:18 AM
NB Cooper's Avatar
NB Cooper
This is a concern only if the clutch is slipping.
Old Sep 7, 2016 | 08:28 AM
cargusjoh's Avatar
cargusjoh
Thanks! I did a measurement. The clutch pedal start at the very top. Goes 3/4" with little/no resistance. Then the clutch pedal is stiff. The clutch disengages very quickly when pushing further. The sensation is it disengagement is very very high. Sounds like no problem.
Old Sep 7, 2016 | 01:21 PM
nkfry's Avatar
nkfry
A high pedal engagement with a stock clutch usually means that your clutch is nearing replacement. You're basically having to take up the difference between flywheel & pressure plate hydraulically, instead of the friction material making contact earlier in pedal travel.
The good news is that Coopers use a single mass flywheel that you can have resurfaced for around $60 usually, then all you need is the clutch assembly and hardware, all of which we have on hand ready to ship if you decide to do the job or whenever the time comes.
Nick
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 7, 2016 | 07:56 PM
cargusjoh's Avatar
cargusjoh
Thanks for your help!
Old Sep 8, 2016 | 08:15 PM
grussell's Avatar
grussell
I thought they were dual mass flywheels.
Old Sep 9, 2016 | 11:55 AM
NB Cooper's Avatar
NB Cooper
Yes from 2007 and up they are dual mass. The older cooper 2002 to 2006 used a single mass / solid flywheel.
Old Sep 9, 2016 | 11:56 AM
nkfry's Avatar
nkfry
G2 Coopers use a single mass flywheel.
Only the S uses a DMF.
Phone:586-792-6464
Old Sep 15, 2016 | 04:33 AM
gjxj's Avatar
gjxj
it is a bit confusing, the part is described as dual mass, although the picture (and price) is obviously a single mass...
http://www.pelicanparts.com/More_Inf...OE&SVSVSI=6355
the s flywhel :
http://www.pelicanparts.com/More_Inf...OE&SVSVSI=6353
betet
May 22, 2016 07:00 PM
cflowrider
Apr 26, 2016 03:25 PM
pj.rodriguez
Cooper (non S)
Mar 22, 2016 10:47 AM
cargusjoh
R55 :: Clubman Talk (2008+)
Mar 17, 2016 12:18 PM
