R56 RMW tune over Manic
Old Sep 4, 2016 | 01:49 PM
BigBoost's Avatar
BigBoost
RMW tune over Manic
I have a buddy that's
been running manic stage 2 map C
for a few month's now
And it has been nothing but problem's
in higher RPM's it fall's flat! then other time's it's great !
it's like a 90/10 mix
And no matter what we try doing, nothing seems to fix it.
so am starting to think its the tune it's self!
keep in mind and a vw/tech for a dealer
so its not likei dont know what am doing.
we've tryed getting a hold of the company he got the tune
from
and they pretty much sad something was broken
and its the car's fault and not the tune.
so
he's thinking about getting a RMW flash tool
Any input on the RMW tune's?
Old Sep 4, 2016 | 02:25 PM
neonsteve's Avatar
neonsteve
Sounds like the turbo needs a new diverter valve. An upgraded version was released this year that no longer uses a diaphragm. The diaphragm is prone to becoming brittle and tearing.
Old Sep 4, 2016 | 02:31 PM
neonsteve's Avatar
neonsteve
Part 11658636606 that ecstuning.com sells is the new part without the diaphragm. You'll see the new part has one large yellow o-ring seal. The old part has the same o-ring but also has a smaller yellow ring visible which is the diaphragm.
Old Sep 4, 2016 | 02:53 PM
MarioKart's Avatar
MarioKart
Vendor
I think it's something with the car. Running map C is around 21.5psi and if you are only running 91 octane, it could cause issues. RMW runs a much lower boost around 18psi
How does the car drive on map B?
mQubed Motorsport, Manic Tuning Dealer
Old Sep 4, 2016 | 05:05 PM
BigBoost's Avatar
BigBoost
we've swap out ecm from my old set up and ran great then put his back in ran like crap ! so we are going with tune! but Am not going to argue if its tune or car!
just seeing if any one's running RMW tune
Old Sep 4, 2016 | 05:32 PM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by BigBoost
we've swap out ecm from my old set up and ran great then put his back in ran like crap ! so we are going with tune! but Am not going to argue if its tune or car! just seeing if any one's running RMW tune
Is your Mini a N18 or N14?
Old Sep 4, 2016 | 06:13 PM
MarioKart's Avatar
MarioKart
Vendor
Last I heard, RMW has only done a few N14's and won't touch anything besides simple bolts ons. He turned away customers with big turbos, cam etc
Old Sep 4, 2016 | 08:30 PM
MiniMoic's Avatar
MiniMoic
Good luck trying to get support from him once you buy the tune. I have the remote tool as a papper weight on my table if you need to use one.
Old Sep 4, 2016 | 09:39 PM
BigBoost's Avatar
BigBoost
yeah' i was on there form page and it seem a little catchy! some of there builded stuff was kind of cool and what ' but my buddy and i have been looking for alternative other the manic! i've never had a problem with the tune i had got ' so am just going to let him run around with my old ecm until he can figure it out! after reading stuff about them i think we are just going to stay away from them' n14
Frankenstein ko4
cam 252
meth
and running 93 octane
he's running exactly what i had on before my rebuild ! so after putting my ecm in his car' it ran great didn't have any problem's nothing! then putting his ecm back in' back to the same old stuff so idk if somehow the ecm got corrupted i really don't know !
Old Sep 4, 2016 | 11:10 PM
Ch28Kid's Avatar
Ch28Kid
This thread is such a click bait.
Old Sep 5, 2016 | 05:45 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Old Sep 5, 2016 | 05:55 AM
MiniMoic's Avatar
MiniMoic
Originally Posted by -=gRay rAvEn=-
Even with what the OP commented? switching ECU´s?
Old Sep 5, 2016 | 06:52 AM
-=gRaY rAvEn=-
Moderator
With RMW tune bet he's seeing 21 to 22/23 lbs of boost. It's a bit more than a stock diverter is designed to handle....each tune is tailor fit to the car. I know a few who have installed the diverters from Audi to remedy.
Old Sep 5, 2016 | 06:59 AM
-=gRaY rAvEn=-
Moderator
....I think its the N18's he hasn't done much with. Seen many N14's done in last 8 years. Hadn't heard about his shying away from MINI's with larger turbo....maybe those candidates he had been approached by hadn't done anything else in support of that mod = risk blowing up the engine ?
Old Sep 5, 2016 | 07:03 AM
MiniMoic's Avatar
MiniMoic
Gotcha. Now it makes sense.
Old Sep 5, 2016 | 09:44 AM
BigBoost's Avatar
BigBoost
Yeah when i was talking to him over facebook that's what he was saying it's not a cookie cutter thing each tune is different.. and as for are diverters we both are running forge upgraded valve's. with upgraded spring's...
Old Sep 5, 2016 | 12:07 PM
minirab's Avatar
minirab
I had Jan tune my R58 JCW at the dragon last year. Had a Forge ic installed prior to
the RMW tune. Its worth it.
Old Sep 5, 2016 | 03:44 PM
BigBoost's Avatar
BigBoost
Originally Posted by minirab
I had Jan tune my R58 JCW at the dragon last year. Had a Forge ic installed prior to the RMW tune. Its worth it.
Yeah' ill have to get a hold of him over the phone! and get the low down first hand! there's so much biased opinion between the two it's hard to say!
what kind of fuel are you running - and what kind of mod's are you running on your r58?
Old Sep 5, 2016 | 03:56 PM
MarioKart's Avatar
MarioKart
Vendor
Yeah' ill have to get a hold of him over the phone! and get the low down first hand! there's so much biased opinion between the two it's hard to say! what kind of fuel are you running - and what kind of mod's are you running on your r58?
Are you really running 11.5 CR or is that a misprint, 10.5 is stock?
Old Sep 5, 2016 | 04:01 PM
BigBoost's Avatar
BigBoost
Are you really running 11.5 CR or is that a misprint, 10.5 is stock? mQubed Motorsport, Manic Tuning Dealer
No misprint' i have a fully built n14 and yes stock is 10.5
but am talking about my buddy's cooper that's having the problem !
Old Sep 6, 2016 | 08:42 AM
minirab's Avatar
minirab
Shell 93. NM intake, resonator delete plus sprint booster, occ, WMW hot side
pipe and the Forge intercooler.
Hendricksen
Oct 30, 2019 08:52 AM
BlwnAway
May 20, 2016 12:07 PM
AFN704
Mar 21, 2016 03:42 PM
johntotah94
Mar 18, 2016 12:34 AM
jmarsz
Tires, Wheels, & Brakes
42
Aug 29, 2005 11:40 AM
