R58 What size swaybar on 2012 R58 JCW
Old Sep 2, 2016 | 02:29 PM
LuvMyJCWCoupe's Avatar
LuvMyJCWCoupe
This question has probably already been asked but I have 2012 Mini R58 JCW. I have the upgraded JCW suspension but I was wondering if it would be worth upgrading both the front and rear sway bars as well as maybe a M7 Under Strut System?
Also does anybody know what the mm size is on the upgraded JCW factory sway bars?
Thanks so much, Alex
Old Sep 3, 2016 | 08:42 AM
minirab's Avatar
minirab
I have the same car as you and a couple of years ago I put on a 25.5 mm Hotchkis
rear bar (hollow). Big difference.
Old Sep 4, 2016 | 08:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Like he said the Hsport comp bar set on the middle setting will be ideal for your MINI.
https://www.waymotorworks.com/h-spor...-sway-bar.html
Old Sep 4, 2016 | 09:11 PM
Fly'n Brick's Avatar
Fly'n Brick
+1 with Way and minirab
A pretty good explanation of the virtues, or lack thereof, concerning the front sway bar can be found on post #2 on the following thread.
https://www.northamericanmotoring.co...sway-bars.html
Old Sep 5, 2016 | 07:14 AM
LuvMyJCWCoupe
Thank you everyone... Just ordered the 25.5 mm Hotchkis rear bar... you guys rock.
Old Sep 6, 2016 | 09:45 PM
adcam's Avatar
adcam
Is this an easy install? I have the same model car.
Old Sep 7, 2016 | 07:04 AM
Fly'n Brick
How to instructions part 1 & 2.
Old Sep 7, 2016 | 09:17 PM
adcam's Avatar
adcam
Thanks for the link, too complicated for me. But Madness is actually close to where I live. Are their 22 mm swaybars as good as the 25.5 Hotchkis?
Old Sep 8, 2016 | 07:26 AM
Fly'n Brick
If you compare the two, the numbers are nearly identical....except.
Madness: +228% +297% +384% $225
Hotchkis: +226% +294% +383% $277
Old Sep 15, 2016 | 03:02 PM
adcam's Avatar
adcam
Got it installed today, what a difference it makes! Should have done this 4 years ago when I got my car!
Old Sep 22, 2016 | 11:00 AM
TheBigNewt's Avatar
TheBigNewt
Hmm, I also have the factory Sport Suspension. I think it's an 18mm rear bar. I may go for the 25.5mm Hotchkiss deal. Any idea who does it in Phoenix? Maybe they do it at Mini North Scottsdale where I bought the car. I had Way put one in my 2007 MCS, a 19mm solid one, Alta I think, at a Las Vegas Mini gathering in 2008.
Old Sep 22, 2016 | 03:26 PM
Fly'n Brick
I'd venture that any good auto mechanic could do the job, it's just nuts and bolts. A dealer's shop charge would be excessive no doubt.
Old Sep 22, 2016 | 09:39 PM
adcam's Avatar
adcam
The rate for labor in the shop that installed was $100/hr and it was 1 1/2 of time.
quickcoop
Dec 4, 2020 09:05 AM
JimmyChooToo
Electrical
Jan 24, 2018 09:30 AM
bahman
Jan 4, 2017 09:17 AM
Suspension Products
Mar 17, 2016 04:17 PM
bhcvc
Aug 13, 2003 02:32 AM
