R50/53 Radiator Fan Compatibility
Old Aug 27, 2016 | 08:31 AM
fancy sauce's Avatar
fancy sauce
Is the early model fan with two connectors compatible with an r53 that only has the single connector with 3 prongs?
Old Aug 28, 2016 | 04:51 AM
cristo's Avatar
cristo
Alliance Member
No.
Not unless you're going to completely rewire it, or unless
you're just swapping the fan itself and splicing it into the
old assembly.
Old Aug 28, 2016 | 05:02 PM
fancy sauce
Thanks. Bought the fan with two connectors on accident. Some of the amazon reviews said you just tie the unused connection out of the way but I wanted to be sure.
Old Aug 28, 2016 | 05:36 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Nope. And I wouldn't try to rewire it either. I would simply return it if that is an option.
///Rich
Old Aug 29, 2016 | 08:43 AM
ZippyNH's Avatar
ZippyNH
The switch was WHERE the relays were....on the fan or on the car....so converting one to the other is imo not really an option...
The remarks about the "extra" connector should have been from 2005+ flowers who had the power steering fan system that was factory modified....the the 2 prong PS fan plug would not be used...it is present on fans for unmodified cars, but can be safely cut off if not needed...the car side 2 prong PS fan plug was moved and rerouted with the 2005+ cars, and any car that was modified so a stick PS fan does not make the radiator fan stop running.
SooperCoopers
Jun 9, 2016 01:46 PM
bkrichards
Jun 5, 2016 06:11 AM
lestavez@yahoo.com
May 31, 2016 11:42 PM
csalinger89
May 31, 2016 05:03 PM
TybeeJim
May 29, 2016 11:14 AM
