2008 Justa radiator replacement
Old Aug 26, 2016 | 04:33 AM
imncrxtc's Avatar
imncrxtc
Hi guys, im going to attempt to change the rad on my car this weekend, do i have to put the car in service position? I hope not, im wondering if anyone has done this before. Any tips?
Old Aug 26, 2016 | 07:31 AM
Sstrickstein's Avatar
Sstrickstein
Just did this to my 2007. You have to pull th bumper cover and remove the ac condenser. Which means you will need a recharge. Spring clip pliers are helpful.
Old Aug 26, 2016 | 08:22 AM
imncrxtc's Avatar
imncrxtc
really.....is that the only way??
Old Aug 26, 2016 | 10:19 AM
3lusive's Avatar
3lusive
Putting the car in service position isn't actually too bad as long as your car isn't rusted to hell. I tried and the front subframe was just too rusty to move at all, even with the bolts out and everything. There's not too many things to disconnect before you have to move the subframe, it's very doable with two people. Bentley manual has a good guide on what to unclip/remove.
Old Aug 27, 2016 | 08:23 AM
imncrxtc's Avatar
imncrxtc
anyone else know if this can be done without service mode position?
Old Aug 28, 2016 | 12:27 AM
Sstrickstein
It's not that service position. The radiator is sandwiched between the core support and the ac condenser. Removing the bumper cover is simply to get access. To get the lower radiator hose connection clear of the core support the ac confessor must be removed.
Old Aug 29, 2016 | 07:43 AM
imncrxtc's Avatar
imncrxtc
On the same topic, do all R56's use the same radiator, excluding the cooper S?
I found a rad with part number - 1711 7535099. Will this fit my 2008 Justa?
Old Aug 30, 2016 | 09:11 AM
3lusive's Avatar
3lusive
http://www.realoem.com/bmw/enUS/show...diagId=17_0391
Looks like that's the right part. This radiator is specific to the base Cooper, but fits across the model line (Hardtop, clubman, etc)
http://www.realoem.com/bmw/enUS/part...&q=17117535099
Old Sep 11, 2016 | 06:15 PM
imncrxtc's Avatar
imncrxtc
Do these r56's use the same BMW coolant as my old R53?
Old Sep 11, 2016 | 06:45 PM
Sstrickstein
Yea I used the blue coolant.
Dimdab
Apr 28, 2016 08:31 AM
sunlover
Apr 26, 2016 01:37 PM
penguinhomey
Apr 9, 2016 04:32 PM
Frixos
Apr 3, 2016 06:12 PM
mmmark
Nov 6, 2005 07:03 PM
