Navigation & Audio Can your radio display play movies?
Old Aug 18, 2016 | 02:13 PM
jetmechinnc's Avatar
jetmechinnc
Just wondered if anyone knows if there is a way to play movies on the display of the F56? I read somewhere you could with either the r56 or r53 if you had the screen for Nav. I have the XL screen with Nav/traffic on my Mini now. But you can't say play a video from your iphone on the screen. But it does show video if using a go pro through the Mini connected app.
Old Aug 18, 2016 | 02:27 PM
Fly'n Brick's Avatar
Fly'n Brick
So, the logical question to this question seems to be: You'll be entertained with the latest from Hollywood instead of the motorized family of four filling your windshield with zero degrees relative bearing drift and a rapidly closing range rate?
Old Aug 18, 2016 | 05:14 PM
ShipM8's Avatar
ShipM8
I had the same thoughts as Fly'n Brick.
Old Aug 18, 2016 | 05:25 PM
siriuszero's Avatar
siriuszero
It is not possible to play video from your iDevice to the car, however, if you do have the XL, it can play most video files from a USB drive plugged into the USB port.
The R56 with Connected could technically do video out from an iPhone/iPod using Apple's PlugIn feature as it output analog video through the AUX port. Unfortunately, when Apple changed from the 30-pin connector to the Lightning connector, they killed that feature off (since the 30-pin had the analog video connections and the Lightning couldn't) and MINI stopped supporting it also.
In both cases, the video would only play while parked.
Old Aug 18, 2016 | 08:17 PM
Fly'n Brick
Being a Gen 1 in-cabin entertainment Luddite, that is good to know.
Old Aug 18, 2016 | 09:09 PM
rkw's Avatar
rkw
It was possible in Gen 1 with a video adapter, and the in-motion block was easily defeated (it merely detected if the parking brake was engaged).
Old Aug 19, 2016 | 05:44 AM
Fly'n Brick
Then the end result of that has to be empty pizza boxes and popcorn all over the floor mats and jujubes stuck to the seats?
quickcoop
Dec 4, 2020 09:05 AM
uslfcfan
Navigation/Audio
14
Oct 31, 2016 08:41 PM
uslfcfan
Mar 28, 2016 08:10 AM
PelicanParts.com
Mar 24, 2016 09:27 AM
PelicanParts.com
Mar 22, 2016 08:44 AM
