R50/53 Recommend alignment specs for my new suspension setup
Old Aug 17, 2016 | 05:28 PM
navybsn's Avatar
navybsn
Finishing up the suspension upgrade on my R53. Now it's time for the alignment. I read several threads with a lot of different alignment specs which have left me a bit confused. So if anyone can opine on this set of numbers for my set up and use, I would appreciate it.
Use: daily driver + 2-3 autox events per year (non-competitive, just fun)
Dampers: Koni Orange front and rear
Springs: TSW
Camber plates: IE fixed
Stock front sway bar
19 mm rear sway bar
Adjustable rear LCA
Poly bushings all around
Pretty standard stuff. If I understand correctly, the front camber will be ~1.9 with the IE plates. I'm thinking somewhere close to 1 would be good for the back. 1/16" toe out in the front and 1/16" toe in in the back. These numbers seem to be reasonable to me, but I I've never had a lowered car or requested a custom alignment. Before I make a costly mistake and have to get the car aligned twice...I would like to hear from the more experienced in the group.
Old Aug 18, 2016 | 01:34 AM
MiniKar's Avatar
MiniKar
I would contact Way, @ Way Motor Works as he does a lot of these Mods.
Old Aug 19, 2016 | 07:25 AM
IQRaceworks's Avatar
IQRaceworks
The IE plates are not adjustable (I have the same ones), and I get around -1.9 camber.
For toe-in, you should be fine....I run around 1/16" toe-in on the front, and close to the same in the back. For a daily driver with a little bit of track time, that sounds just about perfect.
Old Aug 19, 2016 | 04:17 PM
navybsn's Avatar
navybsn
So just back from the alignment shop. The front camber came out weird. -1.0 on the drivers side and -1.9 on the pass side. Makes me think either the suspension needs to settle (drove it straight to the shop) or something is off. I triple checked everything before I put it back on the car, but it's really the only thing I can think of. Any thoughts?
Old Oct 21, 2016 | 05:33 AM
bugeye1031's Avatar
bugeye1031
Moderator
How'd you come out on the alignment?
Old Oct 21, 2016 | 07:58 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
quite a diff but it's fixed you can not adjust it unless you swap them for better plates.
toe out on the front is kind of aggressive
Old Lotus Guy
Apr 7, 2016 04:36 PM
MrBlah
Suspension
Mar 23, 2016 03:17 AM
02MiniS
General Discussion
14
Aug 24, 2003 09:57 PM
jeanna
17
Jul 14, 2002 04:58 PM
cs5887
Jul 12, 2002 09:27 AM
