Will 15x8 et20mm fit?
Old Aug 15, 2016 | 04:12 PM
gta18's Avatar
gta18
http://www.good-win-racing.com/Mazda...t/21-1014.html
Will this fit? I was planning to put 205/50 tires.
Any suggestions?
Old Aug 22, 2016 | 11:58 AM
Alex@tirerack's Avatar
Alex@tirerack
I have fit 8" widths with 35mm fit. 20 is more aggressive, enough you may have rubbing issues.
Old Aug 22, 2016 | 12:46 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Any suggestions?
Which MINI?
What suspension?
Old Aug 22, 2016 | 01:05 PM
gta18's Avatar
gta18
It's an r53 with megans coilovers sorry forgot to mention. Anyway I used the 101tires.com calc and went ahead and ordered and mounted it. It fit beautifully!
Old Aug 23, 2016 | 11:14 AM
Dr. Spade's Avatar
Dr. Spade
Pics? Camber spec?
Old Aug 23, 2016 | 11:43 AM
gta18's Avatar
gta18
Hankook 205/50r15
My megans coilovers are at the lowest height setting. Camber At THE Back Are -1.5 According To My Galaxy note 4.
Old Aug 26, 2016 | 09:17 AM
Alex@tirerack
Can you post a pick from flush with the body at the back of the car? It would be cool to have pic of the poke documented. Thanks
Old Aug 29, 2016 | 01:10 PM
gta18's Avatar
gta18
Been trying to upload but for some reason the site is giving me errors on Token....
Old Aug 31, 2016 | 09:08 AM
gta18's Avatar
gta18
Here's some shots
Attached Thumbnails Will 15x8 et20mm fit?-20160826_123444.jpg   Will 15x8 et20mm fit?-20160826_123436.jpg   Will 15x8 et20mm fit?-20160826_123450.jpg   Will 15x8 et20mm fit?-20160826_123459.jpg
Old Sep 2, 2016 | 07:44 PM
isamin's Avatar
isamin
Evidently you do not drive fast (FAST) or you will brush the lips of MISS DEATH with that setup if there is any compliance in the suspension. Get out the ruler,they don't fit SAFELY. If you're looking to fill the wheel wells I run 235/40/17 on 17x7.5 with ET 45. as a comparison.Also car is dropped 2" and doesn't scrape or rub. Backspacing (ET45) is a critical safety angle.
ISAMIN
Old Sep 2, 2016 | 09:11 PM
gta18's Avatar
gta18
ISAMIN
What do u mean by MISS OF DEATH? What would be the safety concern on this setup? Please educate us on what you mean.
Old Sep 3, 2016 | 05:57 AM
isamin's Avatar
isamin
MISS DEATH is MONSIEUR CYPHER's cousin.
If you drive FAST and ,no matter how stiff your suspension, your car will tend to oscilate and the cheap plastic wheel arches can become as SHARP as razors and will SLICE the sidewalls,possibly causing an accident. Don't take offense as I was just trying to make you aware of potential life ending experiences.
Try it - it can be a WILD RIDE.
ISAMIN
Old Sep 3, 2016 | 07:30 AM
gta18's Avatar
gta18
ISAMIN
Got you. That makes sense. I didn't take those sharp plastic I actually trimmed off a bit to fit my previous set of wheels/tires into account. Thanks for the warning.
Casualrockee
Aug 18, 2016 01:30 PM
PA_Mini
Tires, Wheels, & Brakes
Aug 16, 2016 05:40 AM
DutchMini
Aug 14, 2016 12:07 PM
mvalpreda
Aug 6, 2016 01:29 PM
bosnik
R58 :: Coupé Talk (2012+)
Jul 28, 2016 12:13 PM
