Window switch now working backwards
Old Aug 4, 2016 | 04:25 AM
traildog's Avatar
traildog
I changed the driver side regulator and now the switch works in reverse.
What did I put back together incorrectly?
Old Aug 4, 2016 | 05:50 PM
traildog's Avatar
traildog
Anybody?
Old Aug 4, 2016 | 06:00 PM
RB-MINI's Avatar
RB-MINI
Motor harness was plugged in backwards?? The plugs are usually keyed so this might not even be possible.
Old Aug 5, 2016 | 04:59 AM
traildog's Avatar
traildog
Tried it. Not possible.
Old Aug 5, 2016 | 05:05 AM
whaap's Avatar
whaap
I'm not familiar with that part of the car but can you disconnect the switch and turn it 180?
Old Aug 5, 2016 | 05:09 AM
ZippyNH's Avatar
ZippyNH
Many of the aftermarket regulators and window motors are wired backwards....
Fix is a good regulator, or swap the wires in the plug on it (if possible). eBay parts can be cheap....but they come with issues.
Old Aug 5, 2016 | 05:18 AM
Qik420's Avatar
Qik420
Is there a possibility of the regulators being left or right?
Old Aug 5, 2016 | 06:17 AM
ZippyNH's Avatar
ZippyNH
This issue has appeared MANY times since I have been here....
Usually the culprit is an off brand regulator from e-bay or Amazon.....
It happens in spurts.....a quick search will yield many similar postings....same issue.
Some basic rewireing if one is handy or a different unit fixes it.
Old Aug 5, 2016 | 12:25 PM
traildog's Avatar
traildog
This post got me thinking.....when i pulled the motor off of the old regulator, the top with the brushes came off.
I must have put it back.on incorrectly.
I just turned it around and BINGO. Switch is working normally now.....
Richard_rsp
Jun 30, 2016 03:33 PM
godzilla
Jun 9, 2016 03:57 PM
furnitureman9
R55 :: Clubman Talk (2008+)
May 26, 2016 07:31 PM
Vader-S-All4
May 22, 2016 11:31 PM
HvNd4Speed
May 19, 2016 08:05 AM
