R60 2012 Countryman S All4 Spark plugs
Old Aug 2, 2016 | 10:03 AM
Rayhawk71's Avatar
Rayhawk71
Cool 2012 Countryman S All4 Spark plugs
Hey, y'all!
I've searched forever, trying to find WHERE the spark plugs are located!
Looking under the bonnet, it's not obvious!
Thanks! Ray
Attached Thumbnails 2012 Countryman S All4 Spark plugs-image.jpeg   2012 Countryman S All4 Spark plugs-image.jpg
Old Aug 2, 2016 | 10:22 AM
MarioKart's Avatar
MarioKart
Vendor
It's in the middle, under a black plastic shield, that snaps in and goes around the oil cap
mQubed Motorsport, Manic Tuning Dealer
Old Aug 2, 2016 | 10:29 AM
Rayhawk71's Avatar
Rayhawk71
Originally Posted by Rayhawk71
Hey, y'all!
Thanks! Ray
Thx Mario! I got the "Eng malfunction, ok to proceed, reduced power" msg.
Pulled OBD2 code for #3 cyl misfire. Was going to put #3 plug into #4, & see if the code changes. That should tell me if it's a plug failure & not something else?
Old Aug 2, 2016 | 10:36 AM
siriuszero's Avatar
siriuszero
Pull off the engine cover then carefully pull out the ignition coils to expose the spark plugs.
Old Aug 2, 2016 | 11:30 AM
Rayhawk71's Avatar
Rayhawk71
Thx sirius.. Okey dokey.. Next ?.. looking from the front, what is the cylinders configuration?
Appreciate all your feedback!!
Old Aug 3, 2016 | 08:54 AM
nkfry's Avatar
nkfry
From the front of the engine to the trans side: 1-2-3-4
14mm 12 point socket to remove them, and torque is 18 ft lbs.
No anti-seize, no dielectric, just torque them to spec.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Aug 3, 2016 | 01:23 PM
Rayhawk71's Avatar
Rayhawk71
Thank you everyone, appreciate your help! BTW..took it to dealer & they said needs #3 ign coil (but will only replace as a set of 4), to the tune of $650! Nope! Doesn't need 4! These are replace as needed! They wanted $150 labor (included in quote), for a 5 minute job! All in all, I can do it myself (w/ oem Bremi) for $45!! Sure, there's some value to them pulling OBD2 codes, etc, but come on!!! Geesh!!
Old Aug 3, 2016 | 01:31 PM
nkfry's Avatar
nkfry
I agree with the as needed on coil packs, they don't all fail at once, nor do they take longer than 3 minutes to install.
Start with spark plugs, if that doesn't cure your problem try moving 2 coils around on 3 &4 to see if the misfire follows the coil, if so replace the failed coil.
Phone:586-792-6464
ryanvar42
R60/R61 Stock Problems/Issues
12
Apr 23, 2017 02:26 PM
ceddy1031
Jul 29, 2016 06:16 PM
Witsticka
Jul 28, 2016 06:28 AM
sukonthorn
Jul 13, 2016 07:12 AM
Ruissimo
Jul 10, 2016 04:51 PM
