R50/53 R53 O2 Sensor Voltage Range
Old Jul 29, 2016 | 01:08 PM
cagersguy55's Avatar
cagersguy55
Anyone happen to know the voltage tolerances for the pre and post cat o2 sensors? My car is throwing P0136 (points to post cat), but I'm having all symptoms of precat o2 sensor failure/degradation.
Old Jul 29, 2016 | 02:32 PM
nkfry's Avatar
nkfry
What symptoms are you having?
Catalyst problems can also trigger post cat codes.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jul 29, 2016 | 02:49 PM
cagersguy55
High and Rough idle (usually from 1200-1700 RPM), terrible fuel economy (average about 19 mainly highway), and black exhaust tips (can smell richness also)
Old Jul 29, 2016 | 02:55 PM
nkfry's Avatar
nkfry
I would start looking for vacuum leaks, is the air filter clean? How do the spark plugs read?
What are your fuel trims?
Phone:586-792-6464
Old Jul 29, 2016 | 02:57 PM
cagersguy55
Had a leak down test done that came back negative. Having the codes P0136, P1242, and P0507. Thinking for 1242 that the MAP vacuum tube is cracked or something. Will have to break out the OBD and get back to you on the readings
Old Jul 29, 2016 | 03:02 PM
cagersguy55
Did you want readings at idle or driving?
Old Jul 29, 2016 | 03:03 PM
nkfry's Avatar
nkfry
With those codes I'd say you've got a vacuum leak or a stuck BPV.
Phone:586-792-6464
Old Jul 29, 2016 | 03:04 PM
cagersguy55
BPV was replaced with a DT about 1k ago
Old Jul 29, 2016 | 03:26 PM
cagersguy55
Sensor 1 was jumping all over the place at idle, from about .15v to .76 or so. Sensor 2 was within .01v the whole time.
Michael Nicely
Aug 1, 2016 10:31 AM
AFN704
Jun 7, 2016 12:33 PM
noladude70001
Apr 19, 2016 02:07 PM
ducatiorourke
Apr 19, 2016 01:04 PM
bonz
Dec 3, 2002 05:56 PM
