R50/53 06 mcs overboost?
Old Jul 29, 2016 | 12:03 PM
50shadesofr53's Avatar
50shadesofr53
06 mcs overboost?
I have had my scan Guage 2 hooked up for about a month now, been reading fine everything's normal, out of nowhere today my car started feeling sluggish. Almost like I had the A/C on. Scan Guage is reading no vac at idle, and 26psi at 5k. No svc or eml lights. No codes. Any thoughts ?
Old Jul 29, 2016 | 12:14 PM
BlwnAway's Avatar
BlwnAway
Cat issues will cause your boost to rise, if it's clogged or just starting to clog, it won't throw any codes yet.
Old Jul 29, 2016 | 12:46 PM
Alan Snow's Avatar
Alan Snow
BLWN. BRUH. Stop knowing everything. lol
Old Jul 29, 2016 | 12:58 PM
BlwnAway's Avatar
BlwnAway
Lol... not nearly everything.... but you have to learn something after 12yrs and 200k+ miles.....
Old Jul 29, 2016 | 02:27 PM
nkfry's Avatar
nkfry
A clogged cat would cause problems, but does the Scangauge account for ambient barometrics? 26psi minus 14.7 is 11.3psi which is about normal for a stock car. Did you get any codes? That much of a deviance should've immediately tripped a CEL, especially because the stock MAP sensors can't read that high of pressure.
Was the 26 psi you got at 5k on accel or decel? Because these cars can pull 24-26 in HG of vacuum on overrun.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jul 29, 2016 | 04:56 PM
50shadesofr53
I was pulling 0 vac at idle, and boost as soon as I hit the gas, 5k on half throttle peaking at 28psi. Just scared me because the car acted super sluggish, and shouldn't be making that much boost lol unhooked the battery, and reset my scan guage, all is good
Old Jul 29, 2016 | 05:54 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Shouldn't be seeing 0 vac at idle.
Old Aug 1, 2016 | 07:26 AM
IQRaceworks's Avatar
IQRaceworks
Sounds like you have something going on. Your motor will not run at 0 vac.....how would it suck air/fuel mixture into the motor? You should be seeing around 12-14 vac at idle.
Old Aug 1, 2016 | 08:43 AM
nkfry's Avatar
nkfry
The car will run at 0" HG. Naturally aspirated engines see 0" vac at WOT, and force inducted engines see 0" vac before transitioning to positive intake pressure. The fuel is being injected into the intake ports at pressure along with a slight scavenging effect of the valve opening.
Phone:586-792-6464
Old Aug 1, 2016 | 08:53 AM
IQRaceworks
Yes, you are correct....but i was talking about at idle. The motor will not idle at 0" vac.
Caljae1
R55 :: Clubman Talk (2008+)
May 24, 2016 05:14 PM
cmstan
May 9, 2016 08:32 AM
MiniTigger
May 5, 2016 12:18 PM
MacGuruTX
May 4, 2016 09:00 PM
911***
May 3, 2016 01:03 PM
