R50/53 06 R53 "S" question
Old Jul 20, 2016 | 06:20 PM
PHL_FLYERS's Avatar
PHL_FLYERS
06 R53 "S" question
Has anyone ever experienced the wipers working in what looks like intermittent mode while off?
I was driving to work this morning and all of a sudden my wiper began to work without my turning them on. Also seemed to go quicker when I picked up speed. I tried almost everything to get them to shut off but they wouldn't. Any suggestions would be highly acceptable.
Thanks again
PHL_FLYERS and ELLODJL
Old Jul 20, 2016 | 07:26 PM
Mini Mania's Avatar
Have not personally, but will check with our tech expert. Sounds like a short. Hang in there!
http://new.minimania.com/MINI_Routin..._I_and_II_2344
Old Jul 20, 2016 | 07:48 PM
RB-MINI's Avatar
RB-MINI
Do you have rain sensing wipers or regular? I have mine randomly wipe every so often and then I find somehow the switch was hit and sitting in that position without me knowing. Also, do you have a sunroof. They frequently leak at the drain tubes and the BCM that controls the car gets wet and strange electrical things start to happen.
Old Jul 21, 2016 | 12:43 PM
Mini Mania's Avatar
R53 Electrical
Electrical issues are very difficult to diagnose...
Although there are 2 relays controlling the wiper (on/off & fast/slow), the intermittent function is controlled by the Body Control Module (in the passenger side kick panel).
Since this issue is with the intermittent function, there can be a 'connection issue' between the switch (in the stalk) and the BC module, or maybe a bad ground connection.
Another possibility is a corruption with the software in the BC module (requiring a re-flash by the dealer), or a defective BC module. (these have been reported in the past)
As an inexpensive test, the two relays for the wiper are identical, so you can switch the two to see if the symptoms change. These relays are in the engine compartment fuse box located at the end closest to the firewall. The one in the center is the on/off relay, and the one at the corner is the fast/slow relay).
Hope this helps!
Old Jul 21, 2016 | 04:54 PM
PHL_FLYERS's Avatar
PHL_FLYERS
I do have a sunroof and have check for water inside the car and have found none. I recently made sure the drain tubes from the sunroof were clean. I do not have rain sensing wipers. Thanks for your reply. Will keep my eye on things you mentioned.
Old Jul 21, 2016 | 05:02 PM
PHL_FLYERS's Avatar
PHL_FLYERS
Hope this helps!
When this happened with the wipers I was using my original car key. Because I purchased the car used it only had one key. I ordered a new key at the dealership and strangely I used the new key today and the wipers did not react.
I called the dealership and my feeling is that the old key might have a battery issue because another thing I noticed when the wipers acted up is that when i exited my car and turned it off and closed the car door the car seemed to have locked itself because when i hit the lock button on the old key it didn't work. I unlocked the doors with the old remote then locked them again. Like I said the New remote had no issues today. SO I'm going to try to see if the R53 key has a battery that can be replaced. The dealership also thinks everything is related. Its worth a shot!
Thanks for your info It's great reading material and also gives me something to look at if replacing the battery is not the solution.
Thanks again.
Old Jul 22, 2016 | 02:39 PM
Mini Mania's Avatar
R53
Welcome! Please let us know the outcome.
Old Jul 22, 2016 | 03:35 PM
PHL_FLYERS's Avatar
PHL_FLYERS
Day 2 of driving with my New Key and no issues with wipers. Going to use old key over the weekend and see if the issue comes back. Bad thing is that Battery in the original key is not replaceable. Might have to spring for another key.
Old Jul 22, 2016 | 05:17 PM
RB-MINI's Avatar
RB-MINI
There's a member on the forum who does key repairs, I think even on the non-replaceable battery keys, and can probably replace your rechargeable battery. I don't remember his name, but he posted recently in another key thread.
Old Jul 22, 2016 | 07:37 PM
Filmy's Avatar
Filmy
Pretty sure that's "Valvashon"
Old Jul 23, 2016 | 09:30 AM
PHL_FLYERS's Avatar
PHL_FLYERS
Another member said it was Valvashon. I just sent him a personal message.
Old Jul 23, 2016 | 09:31 AM
PHL_FLYERS's Avatar
PHL_FLYERS
Thanks I just sent him a personal message.
Nov 29, 2018 11:09 AM
jjbunn
Jul 22, 2016 04:41 PM
urrrric
Jun 16, 2016 01:38 PM
Jun 3, 2016 08:38 AM
TC Mini
May 18, 2016 08:05 AM
