FS:: 2005 MINI Cooper S Red (Heavily Modified) RMW
Year: 2005
Model: Hardtop
Price: $15000
Mileage: 124000
Color: Chili Red
Location (Region): SouthEast
So I am selling my 98% completed project car. Here is what you will be getting:
MINI Cooper S Red with the following OEM options:
- Chrono Pak
- Cruise
- Self-Dimming Mirror w/ 3 Button Garage Door
- 2 Keys
- All Books, Manuals and Original Window Sticker
- Limited Slip Differential
- R90/BBS Anthracite Wheels 17” with Run Flats
- Cloth Interior Black/Grey
- Factory HIDs with Black Lenses
- Sunroof
New OEM Parts done during the build:
- Clutch, Pressure Plate and Throw-out Bearing
- AC Compressor, Filter Dryer, and Condenser
- Hydraulic Motor Mount and Lower Motor Mount
- JCW Plugs
- JCW Cat back exhaust
- Complete gasket kit
- Oil Pump
- Water Pump
- Supercharger Serviced
Motor Upgrades:
- Completely re-done motor, balanced and blue printed. Bored .5mm over resulting in a 1.63L motor.
- RMW Forged Pistons
- RMW Forged Rods
- RMW Big Valve Head w/1mm oversized valves
- 450cc Injectors
- RMW Dominator Cam
- RMW Oil Pan Baffle
- ATI Crank Shaft Balancer
- RMW Header w/catalytic convertor
- Way Motor Works 17% underdrive pulley
- ARP Head Stud Kit
- King Race Bearings – Main & Rod
Other upgrades and add ons:
- Pro-Clip iPhone 6+ Mount
- AudioVox Media Bridge Phone Integration System – Plays songs from iDevice with complete radio control
- AquaMist HFS-3 Water / Methanol Injection System with Gauge and Tank System
- Boost Gauge
- GTT Stealth Cold Air Intake
- Maniac MINI Air to Water Intercooler
- OEM MC40 Center Console Gauge Cluster
- RMW / DimSport Flash Tuning Box (with Stock and Current RMW Tunes Stored in memory)
Suspension Upgrades:
- Powerflex Front Lower Control Arm Bushings
- Hotchkis 19mm hollow rear sway bar*
- R56 Rear Trail Arm Conversion Kit*
- JCW Sport Shocks*
- JCW Sport Springs (for the Cooper S with Sunroof, Yes they are specific)*
- NM Lower Adjustable Control Arm/Links*
Brake Upgrades:
- Poor Man’s JCW Brake Conversion (aka R56 front brakes painted Red and JCW stickered)
- Drilled and Slotted Front and Rear Rotors
- Brembo Pads Front and Rear
SO what you are buying is a car that took about 6 months to build, and $22,000+. Car works and runs fine and I have a Dyno sheet showing 228WHP.
The good part:
You get an awesome car for THOUSANDS less than if you decided to do this all yourself.
Its basically a NEW 1st Generation MINI Cooper S underneath with less than 5k miles on it.
Its Fast!
And it was built right with all great parts and by some of the best people to ever touch a MINI.
The Bad:
Driver’s Seat shows wear, but there are fitted seat covers.
The JCW Suspension, R56 Rear Trailing Arms and Hotchkis Rear Sway Bar are all not installed, but are included in the sale.
There is a clunking noise from the front suspension, but that will be fixed by the above parts.
To the buyer, I will provide all paperwork, instructions and information related to the car and the build. I will put you in contact with each of the people that had something to do with the build. This is not a Craigslist car that you are taking a chance on, you will know EVERYTHING. The Price is NOT flexible, if you take an hour or two and price out the parts for the build you will see that there is no flex, so don’t ask. I am SURE that I missed things and I will add them as I remember them or questions related to them come up.
freestylin599
Mar 29, 2016 10:23 PM
